Author Topic: hub caps on Buint wheels?  (Read 1790 times)
96witton
  • USA, VT, shelburne
« on: November 17, 2023, 11:41:36 »
Hi all, I know this is a crazy question, but could I put hub caps on my Buint wheels? the cost of standard wheels and the difficulty getting them is why I ask the question.
thanks for your help. Jim
Re: hub caps on Buint wheels?
« Reply #1 on: November 17, 2023, 12:33:12 »
Yeah that is a bit of a crazy question. Anything is possible of course but I think if you managed to somehow do it, you may end up destroying the integrity of the Bundt wheels in the process.
You must have wheel covers on hand because good ones are not cheap either.
Have you considered offering a trade? You want wheels to take wheel covers. Someone out there may have OEM steel wheels but would rather have Bundts. It’s a thought…
DaveB
« Reply #2 on: November 18, 2023, 07:30:02 »
If you have a 280SL the original steel wheels are the same as the W108 sedan wheels and are not too hard to find. As Michael said, good used wheel covers may be harder to obtain.
But I guess you already know this and you are instead looking for 230/250SL wheels with the 113 part number. That won’t be easy these days.
DaveB
'65 US 230sl 4-speed, DB190
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: November 18, 2023, 19:22:04 »
I have not tried it, but I don't think you can. The Bundt wheels have a center hub that protrudes too far to the outside which will prevent the hubcaps from fitting on the wheels. Also, the outside rim of the forged wheels may not take the hubcap clamps.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
96witton
« Reply #4 on: November 20, 2023, 01:17:57 »
thanks for everyone's comments. Jim
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #5 on: November 20, 2023, 23:58:39 »
As DavidB noted the same size wheels are on the sedans.   Put a wanted ad in your local Facebook Marketplace or Craigslist and you should be able to source 5 of them pretty easily.
Just don't say that they are for a W113 until you have a price   ask for sedan wheels to put winter tires on and maybe you will get lucky and find some aluminum steelies.
Don't pay more than $50 per wheel -  $25 each is a better price
make sure they are straight and check the bolt holes to make sure they are still round and not oval.
Ian
69 280SL
65 F-100
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
08 NPS50
12 Pro 4X
john.mancini
  • USA, FL, Nokomis
« Reply #6 on: November 21, 2023, 15:23:11 »
Alloy (Bundt) wheels will not hold one piece full size hubcaps or two piece (Dog dish) hubcaps. 14" wheels are available, often on Ebay, for not so reasonable prices :) :)Best of luck.
« Last Edit: November 21, 2023, 17:30:03 by john.mancini »
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
