Author Topic: Blower fan wheel rpm (A0008350704)  (Read 3994 times)
babi
  • Hungary, Pest, Budakeszi
« on: November 21, 2023, 18:31:57 »
Hi there!
I made this blower fan (A0008350704, Fan wheel,heater) for a friend of mine. The part is almost ready to use. The last step is the balancing. Does anybody know the rpm of the heater blower motor?
Thank you in advance,
Babi
Philippe VIARD
  • France, Picardie, Aumont en Halatte
Re: Blower fan wheel rpm (A0008350704)
« Reply #1 on: November 25, 2023, 15:51:25 »
Very nice work may interest members
The first speed is 1600 rpm and the second is 2000 rpm
viard
babi
« Reply #2 on: November 26, 2023, 07:44:13 »
Thanks a lot!
I hope it will work well.
kampala
  • USA, CA, Beach Cities
« Reply #3 on: November 26, 2023, 15:09:46 »
Hello, very impressive that you made this part.  Would you explain how you made it?  Is this a printed part?   I don’t need one (yet) but interested in how you made this.
250sl - later - manual
280sl - 1971 - Auto - LSD
babi
« Reply #4 on: November 27, 2023, 12:37:54 »
It was made by 3D printing. I have been 3D printing for almost 1 year. The machine I am lucky enough to use is an SLS 3D printer (Formlabs Fuse 1).
The first step was scanning the existing parts, followed by work in CAD software- the most time-consuming aspect. Once I had the 3D models ready, I chose the right material to be used. PA12 is a strong material with high durability and high impact resistance. Furthermore it is relatively cheap compared to other SLS materials. After printing I painted it. As you can see in the pictures there is a brass shaft. It was made on lathe.
So now I am looking for parts like this and other similar ones for old cars. I think in the future I will be able to produce them.
AndrewB
  • United Kingdom, Channel Islands, Forest
« Reply #5 on: November 27, 2023, 12:46:04 »
Thank you for the work you are doing here. Depending on how much you charge, and how well the printed parts work, I think you might get a good take up for such parts via 3D printing since these blower fans (and other 3D printing suitable parts) are either not available, or cost way too much when provided by the OEM
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
SilverSpear
  • Abu Dhabi, UAE
« Reply #6 on: November 29, 2023, 19:57:44 »
Following...
Euro 2013 Mercedes 350SL
