Author Topic: Oil Pump Clearances M130 Engine  (Read 2197 times)
« on: November 23, 2023, 16:33:49 »
Are the clearances for oil pump for M130 the same as for M127?
We have them in the older edition of BBB for M127. I found a post about them as well.
But I cannot find confirmation if they apply to M130, late, US.
Can you help confirming or directing to correct specs?
Thank you!
Re: Oil Pump Clearances M130 Engine
« Reply #1 on: November 24, 2023, 14:38:06 »
We'll need someone with access to the Tabellenbuch to look this up. Mine are on the old continent and I am in the Wild West unfortunately! But this is indeed an important issue. If I had to guess, I would say the clearances would be the same or very close, but that is only a guess.
« Reply #2 on: November 24, 2023, 17:06:09 »
Thank you for your kind attention Cees. Maybe someone chimes in. I looked at the new BBB today again - just description of changes. Haynes talks about clearances, but they do not give them…
