Author Topic: Long Water Pump Short Bolts  (Read 776 times)
alchemist
  • USA, NY, GRAND ISLAND
« on: November 28, 2023, 22:06:28 »
If you are searching for short bolts for installing the fan to a long water pump, you will be surprised where to find them. Believe it or not they are the same bolts used to fasten the front seats to the floor in early models Mercedes. If you have a local junk yard and it has an older model Mercedes, then, it is the place to visit. The bolts requires 10mm socket and they are easy to remove. Each seat has 4 bolts front and back. If the seat is electric, then search for one that has a manual adjustable seats. Good Luck.
