Author Topic: Block number  (Read 2326 times)
hlsr123
  • USA, CA, Templeton
Block number
« on: December 05, 2023, 22:50:56 »
Hello, I am looking at a 280 Sl with this picture sent to me as a "block number". Can anyone tell me what it means and if it is an original number on 280 Sl or some sort of replacement. I am not an engine person so need some help understanding what it means and if it looks as it should be on an original 280 Sl. Any help is appreciated.
« Last Edit: December 06, 2023, 00:32:29 by hlsr123 »
dirkbalter
  • USA, CA, Corona
Re: Block number
« Reply #1 on: December 05, 2023, 23:00:40 »
I don't see your picture. Assuming you are talking about the stamped engine number, see below:
https://www.sl113.org/wiki/DataCard/EngineNumber
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
Re: Block number
« Reply #2 on: December 06, 2023, 01:19:53 »
If you look at the pointer Dirk sent, you'll see that "130.983 is the engine for the 280 SL (W113)".
The next part, "12", means left-hand drive, automatic transmission.  The final part is the engine serial number.
If you become a Full Member (very worth the relatively small cost), you can find a lot more information about this and other parts of your car in our Technical Manual.
         -David
-David Pease
