Author Topic: Power steering reservoir filters  (Read 1475 times)
CJHenderson
  • USA, AR, Benton
« on: December 16, 2023, 01:06:27 »
When I disassembled the reservoir today, I found two filters in it. Isn't there supposed to be only one? What is the correct order of assembly for the baffle plate, is the plate suppose be on top of the filter, because the baffle plate was under the filter, and it looked like it was interfering with the flow.
1950 MG-TD
Re: Power steering reservoir filters
« Reply #1 on: December 16, 2023, 01:11:48 »
Enclosed.
72 plate
70 filter
Filter, A 000 236 00 55, available at dealers.
MikeSimon
  • USA, OH, North Royalton
« Reply #2 on: December 18, 2023, 16:26:58 »
We (Vickers) supplied the filter for the reservoir. During my time, it was a one-piece filter. I have one somewhere and will take a picture later today.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
MikeSimon
« Reply #3 on: December 18, 2023, 18:47:46 »
CJ: Here are some pics of the filter. Not sure whether the p/n that Pawel lists will give you this. I am using these in my 280SL.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #4 on: December 18, 2023, 21:23:15 »
I recall on my 230SL it works like in the diagram above.  You drop in the cylindrical filter, drop the plate on top of it and the other parts, and the lid holds it all down tight.
« Reply #5 on: December 18, 2023, 23:19:27 »
Those are for later cars. Some will interchange with the ring type filter but not the 113 system.
« Reply #6 on: December 19, 2023, 06:28:59 »
Ditto with the Benz Doctor!
WRe
« Reply #7 on: December 19, 2023, 06:40:09 »
in contrast to the newer paper filters the old filters could be washed out.
...WRe
« Reply #8 on: December 19, 2023, 10:52:00 »
I bought it a year or two ago and what you get from Mercedes is exactly what WRe is showing - hard pumice (or whatever the word is), a spongy stone material.
MikeSimon
« Reply #9 on: December 19, 2023, 14:19:01 »
Not sure what this exactly means, but I am using these in my 1971 280SL and they work fine. The funny thing is, the filter "filters" the fluid coming from the return line into the reservoir, not from the reservoir going into the pump.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
WRe
« Reply #10 on: December 19, 2023, 14:58:10 »
Hi Mike,
if you look in the Mann filter catalog, you will find the H85 paper filter you use in the later models.
https://catalog.mann-filter.com/EU/eng/catalog/MANN-FILTER%20Katalog%20Europa/Hydraulic%20steering/H%2085
...WRe
