Author Topic: Voltage regulator black wire  (Read 1361 times)
cfm65@me.com
  • Cape Town, South Africa
« on: December 16, 2023, 08:39:04 »
Hi Guys,
Could someone please let me know where this black wire originates? This end is dead, no + no -.
Much appreciated.
Regards
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
BobH
Re: Voltage regulator black wire
« Reply #1 on: December 16, 2023, 11:01:20 »
Hello Chris, the black wire connects to terminal DF on the alternator, i think you'll only see a voltage there when the engine is running
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
lpeterssen
  • USA, FL, Miami
« Reply #2 on: December 16, 2023, 11:09:27 »
Dear Chris
Bob is right, none of those cables will show anything unless the alternator is operating.  You have one brown , cable connected to “D-“ which is a ground one terminal with two cables one blue and the other red/blue which are connected to terminal “D+”  and run your charge light at the instrument cluster. And finally the black cable you mention which goes in between join8ng terminals labeled “DF” at voltage regulator and alternator.
Best regards
L.peterssen
cfm65@me.com
« Reply #3 on: December 16, 2023, 11:11:41 »
Apologies guys,
This is the voltage regulator on my E Type and it was supposed to be posted on the Jag forum.
The wires are brown/purple, black, brown/green.
Thanks, I’ll give it a go.
Much appreciated.
Regards
Chris
« Last Edit: December 16, 2023, 11:17:25 by cfm65@me.com »
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
BobH
« Reply #4 on: December 16, 2023, 11:35:02 »
Ah, totally different, looks like the black is an earth/ground, see if you can trace it and see if it's a bad connection somewhere
Perhaps this post should be moved to other cars in case it causes confusion
« Last Edit: December 16, 2023, 11:41:46 by BobH »
UK delivered RHD
Blue soft top
Blue leather
