Author Topic: Engine number vs. chassis number  (Read 4396 times)
desousa
  • Portugal, Porto, Porto
« on: December 16, 2023, 17:12:43 »
My first post….
Just bought a 1964 LHD 230 SL.
Chassis number 113.042-10-005062
Engine number 127.981-10-013754
The engine number seems to indicate that it is much more recent than the car, i.e. the original engine was replaced at some point.
Correct? Any way to estimate the engine date of manufacture?
Thank.
Jose
1964 MB 230SL
1928 Alvis  FD12/50 FWD
1932 Alvis Speed 20SA
1933 Alvis Speed 20SA
1950 Aston Martin DB2 DHC Prototype
1951 Aston Martin DB2
1952 Lagonda 2.6 DHC
1956 MG Magnette
1957 Chevrolet BelAir
1960 Chevrolet Corvette
1968 Volvo 142S
1970 Aston Martin DB6Mk2
2007 Aston Martin Vanquish S
Re: Engine number vs. chassis number
« Reply #1 on: December 16, 2023, 17:30:03 »
Do you have the original Data Card? This will tell you the information regarding the engine number and whether its original to the car. You can purchase these from the Classic Center in Germany.
I don't know that there is as comprehensive a list indicating engine serial numbers keyed to manufacture dates like there is VIN to manufacture date.
Much of the detail on these kinds of things is in our Technical Manual, which you can view if you are a full member.
« Reply #2 on: December 16, 2023, 17:43:36 »
Jose,
Welcome to the group, and I will echo Michael's comment about joining as a full member. For $30 you have access to the full data base and technical manual. You also would receive Pagoda World magazine (twice a year) and Pagoda Notes newsletter four times a year.
The issue of engine numbers and date can get very complicate very quickly. You can try the "Search" functionality (fourth item to the right of "Home")
I used "Engine Number" with the quotes - that limits the search to those two words together. I got ten pages of hits, so this is regularly search. You can look through the first page or two to get an idea about the difficulties with finding the date.
The best arbiter is to get a copy of the data card from MB to get the car codes as it left the factory. You should be able to get that through the dealer. There is a fee of about $150 - don't know if they charge the same amount in Euros though.
mauro12
  • Italy, Sicily, Messina
« Reply #3 on: December 16, 2023, 18:33:47 »
I believe that there is no direct connection between vin and engine number but maybe I’m wrong . It’s a pity that now is on payment the data card . I got it in 2017 and was totally free. 150€ seems a bit too much .
Mauro Pisani
250sl 1967 5speed zf manual
BobH
« Reply #4 on: December 16, 2023, 18:59:31 »
Hello Jose, in the technical manual there is a register of members cars with VIN's, and some have their engine numbers listed.  You can search the engine number column for one with a number close to yours and this will give you a date close to the year of manufacture of your engine.  The columns are sortable to make the search easier.  Don't forget to look at only the 127.981-10- engines
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #5 on: December 16, 2023, 19:51:07 »
Congratulations on your purchase. You've found your new favorite website!
If originality and history are interesting or important to you, then buy the data card. It has lots of info you will like to know, including the original engine number. Maybe buy from Classic Center, maybe from local dealer?
Chassis and engine numbers are not supposed to be the same.
Get acquainted with search feature on this forum, we've been online 20 years!
« Reply #6 on: December 16, 2023, 21:23:40 »
You have to remember that the engine numbers sequence is separate for manual and automatic. They will always be more or less apart, depending on proportion between automatic and manual cars being ordered in given period of time.
So yes - your engine can come from your car even though the numbers are far apart. However, as advised, it is best to obtain datacard form dealers (Classic Center, I think, no longer deals with them). Yes, you have to pay some fee for that, but it is worth it.
It is also more than worth it to pay small fee here and have access to experts and all the secrets of these beautiful cars.
Jordan
  • Canada, ON, Jordan
« Reply #7 on: December 17, 2023, 02:30:33 »
Jose, as mentioned, get the data card which will confirm the correct engine number for your car.   That being said I would guess you have a 230SL engine from late 1966.  Your original engine number will probably be less than your VIN, that is the last 6 digits will be less than 005062.  I would guess your original engine's last digits would be somewhere between 004400 and 004600.
Marcus
66 230SL  Euro 4 speed
MikeSimon
  • USA, OH, North Royalton
« Reply #8 on: December 17, 2023, 12:55:58 »
This being correct, Pawel, it supports the fact that his engine number should be "lower" than the chassis number. While the VIN numbers did NOT have two separate sequences, they run higher in the serial number than the engine number, which had two separate sequences.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #9 on: December 17, 2023, 13:26:58 »
That is true, you're right.
When you scroll through the Car Register - in 95% of cases it is that engine number is lower than chassis number, although sometimes the differences are surprisingly huge.
There, however, examples of engine number being higher (I did not look through to the very end of the Register):
113.042 20 000289   127.981 20 005740
113.042 10 010333   127.981 10 012501
Probably some kind of swaps - I have no idea. Datacard is necessary to understand this.
« Reply #10 on: December 17, 2023, 13:49:29 »
Of course, the possibility of swaps exists.  Equally possible is that a quantity of "127.981.10" and "127.981.12" engines were withdrawn from production to provide future warranty spares in preparation for the changeover from 230SL to 250SL . . .
« Reply #11 on: December 17, 2023, 13:58:29 »
Yes, some kind of factory inventory management case crossed my mind as well, but did not want to speculate. Some stock re-manufacturing due to demand change also cross my mind - there can be 1000 explanations.
I think to find out we would need:
1. Datacard. But knowing there are mistakes in datacards -
2. Picture of the number on the engine block (actual number and style it is stamped)
3. Info on presence, picture of Tauschagregat plate
4. Picture of stamped VIN
5. Car VIN plate
6. Paint code plate would not harm either (aufbau vs. vin)
Then we would have it cross-checked left and right.
john.mancini
  • USA, FL, Nokomis
« Reply #12 on: December 18, 2023, 15:03:39 »
Welcome Jose and congratulations on your 230SL.  These are great cars and this is the best collector car forum on the planet. I echo my fellow members' sentiment.........become a full time member. You'll find the most helpful information and the friendliest group of people who have a wealth of knowledge.
It was not uncommon for MB to perform engine block replacements back in the day. I'm sure it's much less common today. That being said, I would agree that your data card will provide you the answers pertaining to your engine number.
Good luck with your 230SL. I have a 65 230SL.
John
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
« Reply #13 on: December 18, 2023, 15:24:59 »
We need Jose to check back in with us!  I think new members posting for first time don't realize how active the group is and how many replies they will get in 48 hours, or even 6 hours!
MikeSimon
« Reply #14 on: December 20, 2023, 20:42:20 »
One other thing that makes me think: The engine serial number is over 13,000. Considering that there are two sequences, one for manual trans - 10- and one for AT -02 -, and that a little over 20,000 230SLs were made, it seems strange that there were over 13,000 manual transmission engines? Maybe it is a (not-so) clever e-stamp?
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #15 on: December 20, 2023, 21:23:21 »
Indeed odd… have not thought about it. Difficult to figure out without more data points…
DavidAPease
  • USA, CA, Chico
« Reply #16 on: December 20, 2023, 22:10:23 »
Quote
I believe that I have read that the vast majority of 230SLs were manual transmission.  For example, my '66 automatic is chassis (VIN) number 015461 (more than 3/4 of the way through the entire run of 230s), yet my engine number is only number 003868.  Presumably, this means that there were already around 11,600 manual transmission engines built by early 1966.
So, maybe not so strange.
            -David
-David Pease
« Reply #17 on: December 21, 2023, 06:23:00 »
My auto Sept 1965 VIN 12948 has engine number 2801 as per data card giving further weight to the idea.
« Last Edit: December 21, 2023, 21:49:05 by Garry »
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
AdelaidePagoda
  • Australia, South Australia
« Reply #18 on: December 21, 2023, 11:55:42 »
Another data point: Mine is manual Jan 64 VIN 2101 and Engine 1982
Dave
January 1964 230SL 4SPD Power Steering
050 050 Black Soft top, Red Leather interior
Italian delivered/ Germany/ Florida/ Boston/ Sydney/ Adelaide (5th owner)
Model S Tesla
Vespa
BobH
« Reply #19 on: December 21, 2023, 12:06:22 »
I read on another forum that an estimated 70% of 230's were manual, which calculates to around 13,880 cars.  The highest manual trans engine number i can find after a quick look on the registry is engine number 14725 on VIN 19694, this is a 1966 car, so possibly a replacement engine.  Perhaps there were slightly more than 70%, even accounting for engine replacements over the years
« Last Edit: December 21, 2023, 12:15:57 by BobH »
UK delivered RHD
Blue soft top
Blue leather
Jordan
« Reply #20 on: December 21, 2023, 14:38:19 »
I think that engine number is correct for that car.  My VIN is about 1000 less and my engine number is 14145.  That 230SL is only 43 cars from the last 230SL.  If we subtract the engine number from the VIN, we get 4969, which is probably about the number of automatics that were made.  So about 75% of the 230SL's would have been manual.  It's a simplistic way of calculating but probably pretty accurate.
Marcus
BobH
« Reply #21 on: December 21, 2023, 14:58:15 »
Hello Marcus, that's correct, now i check again the car was a December 66 build, only a  month away from end of production
UK delivered RHD
Blue soft top
Blue leather
desousa
« Reply #22 on: December 23, 2023, 23:03:56 »
Thank you all. I now have a copy of the data card and the original engine was 4402, which seems correct for chassis 5062.
This means of course that the engine in the car (13754) is a later replacement.
No wonder it is in such a great shape.
But I had to get a new cold start thermostat, which goes for a pornographic price…
1964 MB 230SL
1956 MG Magnette
1968 Volvo 142S
« Reply #23 on: December 23, 2023, 23:28:41 »
May I ask: did you obtain the datacard form the dealer or some other way - just so that we know?
Well, you may get used to obscene prices for some of the components...
If I may suggest - always check the prices at the dealers as well. You have your thermostat in Niemoeller's at EUR 800 plus and at Mercedes for ca EUR 780.
desousa
« Reply #24 on: December 25, 2023, 21:42:43 »
Thank you for your comments Pawel66.
Data card copy came with the car. I just did not have it with me when I posted…
Yes, I paid £780, so typical obscene price…
1964 MB 230SL
1956 MG Magnette
1968 Volvo 142S
