Author Topic: How do I dismantle this?  (Read 2319 times)
Merc_Girl
« on: December 19, 2023, 20:52:33 »
Hi everyone
Yet again seeking out the great knowledge held in the forum 😀
So, I’m dismantling chrome items to have rechromed.
The item in question is the sun visor mount. One was very easy as only a screw holding it in place. However the other one has what looks like a chrome cap on top? Have tried prizing it off and even tapping the bar from the other side to loosen, but to no avail
Does anyone have any idea/cunning plan as to how to separate the bracket from the arm?
Photo attached
Any ideas greatfully received 🥹
230SL
BHap
  • USA, PA, Pittsburgh
Re: How do I dismantle this?
« Reply #1 on: December 20, 2023, 03:54:55 »
Can you push the rod further into the bracket to raise the chrome cap enough to see if there is a circlip holding it in?
The other thought would be some sort or spring loaded ball bearing that holds the rod into a groove on the inside of the bracket.  If this is the case, some light oil worked in and a swift tap on the chrome cap end with a brass punch may move the ball out of the groove.
Both total guesses - good luck!
Bob Happe
Pittsburgh, Pa
BobH
« Reply #2 on: December 20, 2023, 10:00:32 »
Hello Katie, can you take a picture of the other side of the bracket, the side that fixes to the car, to see what's actually inside there, may give a clue.  What was on the other visor, you say the cap was missing, how was that fixed, perhaps a picture of that would help as well
I've seen some new repro's where the whole cap had a screw slot on it, so the whole thing screwed off
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
450sl
« Reply #3 on: December 20, 2023, 10:22:45 »
i would just prepare it  (polish)  and send it as an assembly to the chromers.
do8erman
  • United Kingdom, England, Ware
« Reply #4 on: December 20, 2023, 11:19:54 »
done this . It's a push fit and being aluminium easy to damage . Needs prising out to access the screw
Merc_Girl
« Reply #5 on: December 20, 2023, 19:03:29 »
Thank you all!
Gave up and sent for chroming intact!
Would anyone know if these can still be bought?
Many thanks again
Katie
230SL
« Reply #6 on: December 20, 2023, 21:27:46 »
Katie, I think so. If it is an early style sunshade hinge, check out SLS-HH store. Perhaps they also have it in the SL shop.
Merc_Girl
« Reply #7 on: December 20, 2023, 23:22:07 »
Thank you
Did have a quick look but they only appear to sell the whole item, not just the little cap.
Will email them and see if they have anything. If that’s no good, there’s an engineering place near me who perhaps could make some stainless ones 😁
230SL
do8erman
« Reply #8 on: December 21, 2023, 12:41:00 »
EBay  chrome plastic cap
do8erman
« Reply #9 on: December 21, 2023, 14:01:19 »
Should have read chrome plastic end cap or tube insert
Merc_Girl
« Reply #10 on: December 21, 2023, 17:06:35 »
Thank you!
Very cunning plan by both of you 😁
230SL
