Author Topic: Chrome plate taillight without removing the lens  (Read 2181 times)
Joe
  • USA, CO, Colorado Springs
« on: December 20, 2023, 17:26:47 »
Has anyone had this done to an early part with the non removable lens?
Joe
« Last Edit: December 20, 2023, 17:49:06 by Joe »
Re: Chrome plate taillight without removing the lens
« Reply #1 on: December 20, 2023, 21:19:42 »
The lens can be removed for rechroming the outer surround. Slow and steady is the key to success.
https://www.sl113.org/forums/index.php?topic=22351.msg160153#msg160153
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #2 on: December 20, 2023, 22:29:46 »
Depending on the cost of re-chroming you may be better off buying a new one.  I think there are vendors selling them again.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
Joe
« Reply #3 on: December 21, 2023, 15:11:27 »
Thanks. Now, how do I remove the silvered part glued to the back of the lens? It has to come off to reach the tabs.
Joe
VikDasor
  • United Kingdom, England, Uxbridge
« Reply #4 on: December 21, 2023, 22:34:41 »
Hi Joe
I just had all my outer chrome rechromed and just a heads up on the rear light surround just make sure the chromers don’t put heavy chrome on the light surround after you have removed your lenses as they will not fit back in. That is the issue I am having at the moment.
Vik Dasor
1966 W113 230SL
1988 R107 300SL
1999 R129 320SL
Porsche 911 997 C4S
Joe
« Reply #5 on: December 22, 2023, 04:40:51 »
Good point
BobH
« Reply #6 on: December 22, 2023, 08:39:39 »
Joe
From what i understand the reflector should just be clipped into the lense, not glued in?
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
« Reply #7 on: December 22, 2023, 11:11:30 »
It can be done but you'll end up with a roough edge where the chrome meets the lens.
Mercedes sells new ones but annoyingly, they are plastic repros!
