Author Topic: Striker plate  (Read 1501 times)
col320ce
Striker plate
« on: December 23, 2023, 03:04:23 »
My striker plates have "loose" catches on them so I want to replace them as the doors keep popping open (1964 230SL).  The part numbers I have are 110 720 05 04 and 110 720 06 04 but I think there are revised part numbers but I'm not sure what they are (maybe 110 720 12 04 but not sure if this is left or right)... can anyone help?
Niemoller have them and they are a little cheaper than the MB classic center (classic center has the 110 720 12 04).  Anyone have experience with the ones from Niemoller or the classic center?
Col
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
Re: Striker plate
« Reply #1 on: December 23, 2023, 09:47:32 »
You have to double check with the Classic Center the VIN numbers these parts are meant for. The part number you quoted is the right hand side one for VIN up to ident. no.: 043 002979. Then there was a change with higher 113044 VIN number (044 010365).
Yes, there were different PNs for these parts before (A 110 720 06 04) but they were replaced with those you are looking at.
Good overview is here:
https://www.sl113.org/wiki/ChassisBody/Doors#Latch
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/72-door/72-b-info-door-catch
I replaced both (later ones) with parts from Mercedes and they are just fine. No experience with Niemoeller or SLS parts. I see, however, a very similar price - for me it would be clear to go for the original one, but I have only experience with the later one from Mercedes.
I was advised here to really make sure what causes slack in my door latches to replace the correct part. My decision was that it was the bushing inside rubber in the catches got worn out. So I replaced both catches and my life has changed in terms of how the doors close and stay tight.
col320ce
Re: Striker plate
« Reply #2 on: December 27, 2023, 17:48:25 »
Thanks Pawel!
Col
1964 230SL
1965 250SE coupe
