Author Topic: Now available Mercedes W113 LHD MANUAL wiring harness  (Read 2270 times)
lpeterssen
  • USA, FL, Miami
« on: December 29, 2023, 17:49:53 »
Dear Friends
Just finished another MAIN WIRING HARNESS for Mercedes Pagoda W113-230SL LHD MANUAL transmission.
This is an EURO SPEC version harness. So you can install the EURO STYLE HEADLAMPS and everything wil work seamlessly.
Its available at my store for sale at 1499$
Photos album : https://www.icloud.com/sharedalbum/#B0QGTI3fvGXe0Hb
Main features:
1. Ready to run on Bosch AL69X internally regulated alternator.  Terminals and line sizes upgraded to fit that larger alternator which will produce 80A.
2. Upgrade Cold start Logic.  This harness will run on 280SL LATER Cold start logic.  So with this harness your loved 230SL will have much easier Cold and hot startups.
3. Upgrade to run on w116/126 or Porsche TTS (thermo time switch) wiring and terminals  changed.
4. All general refurbishing aspects completed in full to give you confidence that this harness will perform as new.
5. All terminals carefully polished and labeled to make re installation a piece of cake.
6. Main fuse box included and finely polished all its contacts to better than new condition.
7. Some extra goodies added for your confort and convenience:
7.1 horn contacts with two kinds of interchangeable connectors.  You can use tongue shaped terminals for old style horn post or you can also use modern horns with spade kind plug.
7.2 main cabin light with a plug in connector to make your life easier.
7.3 tachometer and speedometer illumination terminals with detachable connector on each case.  So you can screw in terminals at tacho or speedometer and then just plug that cable branch to main harness via a plug in connector.
Best regards
Leo Peterssen
« Last Edit: January 01, 2024, 20:27:56 by lpeterssen »
lpeterssen
  • USA, FL, Miami
DIRECT LINK Now available Mercedes W113 LHD MANUAL wiring harness
« Reply #1 on: December 31, 2023, 00:19:01 »
Here my friends link on my store for this wiring harness
https://wiredoktor.com/products/mb-w113-230sl-lhd-manual-main-harness
dirkbalter
  • USA, CA, Corona
Re: Now available Mercedes W113 LHD MANUAL wiring harness
« Reply #2 on: December 31, 2023, 03:18:40 »
Thats a great price. From what it looks like you supply all the connectors as well.
Happy new year.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
lpeterssen
  • USA, FL, Miami
« Reply #3 on: December 31, 2023, 11:15:24 »
Thanks  Dirk.  Happy new year for you too.
Yes all the connectors are included on the price as well as the main fuse box.
Regards
LP
Www.wiredoktor.com
