with our official
Pagoda SL Group logo
from our official partner.
Injection problem?
Topic: Injection problem? (Read 5083 times)
JJD
Full Member
Junior Level
Netherlands, Gelderland, Doorwerth
Injection problem?
July 17, 2005, 14:38:34 »
Since a few days my 1970 280SL developed a funny problem.
When driving above 40 MPH keeping the gaspedal in the same position the engines revs go up and down a couple of times per minute (the car accelarates or slows down a bit). It does it when the engine is cold or hot. The engine starts okay and does not stall. At low speeds you don't notice.
John Dreu
Enjoying every minute in my 280SL
Full Member
Platinum
USA, CA, De Luz and Los Angeles
Re: Injection problem?
July 17, 2005, 14:47:34 »
Could this be in the ignition (vacuum advance/retard behaving erratically for example)?
BHap
Full Member
Senior
USA, PA, Pittsburgh
Reply #2 on:
July 17, 2005, 16:49:55 »
sounds like fuel starvation.... fuel pump beginning to fail, fuel filter or inlet screen on fuel pump would be my first suspects...
Bob Happe
Pittsburgh, Pa
Reply #3 on:
July 17, 2005, 19:11:02 »
In the event Cees is on to something, disconnect the connector from the base of the two way valve and go for a drive. If the problem continues its not the emissions control stuff. If it goes away let us know and we can work on fixing the problem.
Full Member
Platinum
USA, OH, Canal Winchester
Pagoda SL Group: 20+ years and going strong!
Reply #4 on:
July 17, 2005, 21:58:04 »
Could it be in the distributor? Broken springs, worn shaft, etc.?
1966 230SL, Euro, Auto, Leather, both tops
blairwag
Reply #5 on:
July 17, 2005, 22:21:46 »
Hummm, I think that the distributor retard should be fully engaged by or before 40MPH. I'm apt to suspect fuel delivery, too. I'd replace the fuel filter first. If it persists, I'd find a way to measure the fuel pressure.
1971 280SL US Automatic
Full Member
Platinum
Australia, Queensland, Brisbane
Reply #6 on:
July 18, 2005, 05:53:23 »
I agree with Rodd,
possibly the distributor springs gone soft or broken.
A cheap quick test to eliminate this suggestion...remove the distributor cap and turn the rotor clockwise and let it go. It should spring back easily and quickly.
While in there check the points gap and clean the inside with a dry cloth.
See if the felt wick in the top of the distributor shaft is dry. If yes give it an oil with 2-3 drop of oil and then add 2-3 drops to the oil point on the outside of the distributor.
What have you got to lose?
JJD
Full Member
Junior Level
Reply #7 on:
June 29, 2009, 15:28:21 »
Just to finish this thread.
I found the issue. It was the emmission reduction electronics (Relays) that didn't work properly.
Last Edit: June 29, 2009, 17:58:53 by vanesp
John Dreu
Injection problem?
