Author Topic: 5 speed from auto?  (Read 1562 times)
Ahealey12
  • USA, TX, San Antonio
5 speed from auto?
« on: January 07, 2024, 20:56:57 »
Inheriting a 230sl and bringing it back home in next few months. Brakes went out a couple years ago and so it’s just been sitting. I remember when last driving it myself the auto transmission was not doing well.
With only 100hp I’d love to be able to swap out a 5 speed since i know engine swap would devalue the car quite a bit and trans already on way out.
Reading through forum a bit- w 230sl is it that i just reuse the flywheel from the auto and put in a pilot bearing? Is there anywhere i can get a bell housing?
Looking at this kit: https://drivenman.com/product/mercedes-280sl-5-speed-conversion-kit/
And yes I’d love to throw an ls and different rear end in but trying to make this fun as is and not upset the purists 😅
Also what model pedal assemblies would work?
1967 230sl auto
1967 Chevelle ls swap
1968 bronco ls swap project
2022 zl1 Camaro
2021 Range Rover velar daily family car
GM
  • USA, CA, San Pedro
Re: 5 speed from auto?
« Reply #1 on: January 08, 2024, 17:08:12 »
Looks like this kit is to convert a manual 4-speed to a 5-speed
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
« Reply #2 on: January 08, 2024, 20:15:56 »
Welcome to the Group!
There has been a lot written over the years about transmission swaps, so keep using that search feature (and others will reply here) for further self-education.
Some people use a 4 speed manual, most a 5 speed.  There are specific transmission models recommended.  Some people with a factory 4 speed manual add an Overdrive unit.  Some people just swap the rear differential to drop the RPMs.  Some people swap out the whole rear axle for one from a 280 sedan, as they have a 3.27 diff, but then you have to do brake work as you would be changing rear brakes from drum to disk.
The 4-speed auto behaves like a 3-speed because the stump-pulling first gear is only engaged by the kick-down switch on the floorboard, or by putting the gear selector in "2".  I never had a complaint about my auto in my 230SL.  But, I don't mind the high RPMs relative to modern cars, or even US domestic cars of the 60's.  My 230SL has the 3.75 rear axle ratio, so that helps some!   ;)
« Reply #3 on: January 08, 2024, 20:28:00 »
lowpad
  • USA, CT, New Preston
« Reply #4 on: January 09, 2024, 04:29:05 »
Has anyone installed the Driven Man Tremec kit on a 230SL? I've searched the forum, but can only find reference to the Bud's Tremec kit (I'd like to hear from someone that's done it themselves). Appreciate any counsel.
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
Alex D
  • USA, NC, Cary
« Reply #5 on: January 09, 2024, 17:34:22 »
Currently in process of replacing the 4 speed manual with a 5 speed Tremec from the Drivenman in Cookeville, Tennessee, along with some other mechanical work being done.  Will advise how  the Tremec 5 speed is working in a few weeks.
Alex
Alex D
1967 250 SL
Original 140K mi
181 Light Beige, with  112 Turquoise Interior
cfm65@me.com
  • Cape Town, South Africa
« Reply #6 on: January 09, 2024, 18:13:32 »
Ahealey 12.
I recently replaced the auto box of my 250SL with a 5 speed Getrag transmission and loving it. It has transformed the Pagoda completely. It now nearly feels like a sports car. The 250 obviously has a little more oomph that the 230, but still not a ball of fire but I love it.
I have a spare Getrag which I am considering to install in my E Type.
Back to the Pagoda. It is quite easy to get the parts to fit the Getrag. There are a few guys who make up and sell ‘kits’ to install the gearbox. I collected a lot of parts from breakers and cobbled most of the rest together and installed the gearbox myself.
There are a lot of information re this conversion on the internet.
Good luck.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Ahealey12
« Reply #7 on: January 12, 2024, 00:21:07 »
Was there anything that needed to be changed with the balance if the auto engine? Or does it house a flywheel as well? I guess that’s what I’m mostly confused about. I’m used to small block fords and chevys that you just need to change a flywheel to match. Reading i have found a lot of people mention engine beefing to be rebalanced completely from auto to manual?
1967 230sl auto
2022 zl1 Camaro
dirkbalter
  • USA, CA, Corona
« Reply #8 on: January 12, 2024, 15:11:35 »
On the 230is the crank and the flywheel are balanced as one unit.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
cfm65@me.com
« Reply #9 on: January 12, 2024, 17:19:47 »
I took a chance not balancing the flywheel/crank assembly on my 250 and it worked out just fine.
Regards
Chris
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
dirkbalter
  • USA, CA, Corona
« Reply #10 on: January 12, 2024, 19:11:54 »
Regards
Chris
I believe it does not apply to the 250 / 280.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #11 on: February 18, 2024, 21:32:36 »
Inheriting a 230sl ... With only 100hp ...
It's 150hp when new.
