Author Topic: Lubricating the fuel injection pump  (Read 2788 times)
blairwag
« on: July 17, 2005, 20:40:31 »
In my repair nightmare this weekend, I decided to lube the chassis. Checking some of the manuals, I was alarmed to see the recommendation of renewing the oil in the fuel injection pump.
I've got a 1971 280SL. In reading the BBB, Haynes Workshop manual, and Chilton Repair manual, I've gotten myself confused. Originally, I thought that the fuel injection pump used the same oil as the engine crank case, and that oil was curculated from the crank case, through the injection pump. Is that not true? ... or do I need to drain and refill the fuel injection pump with motor oil as part of my routine maintenance?  Does this thing have an oil filter that should be routinely replaced?
1971 280SL US Automatic
Re: Lubricating the fuel injection pump
« Reply #1 on: July 17, 2005, 21:21:59 »
Hello William,
Only the early fuel injection pumps had the isolated oil supply. Your 280SL has an injection pump which has engine oil circulating through it. No oil change required.
« Last Edit: July 17, 2005, 21:23:08 by ja17 »
blairwag
« Reply #2 on: July 17, 2005, 21:48:16 »
Shew! Thanks, Joe, for confirmation.
