Author Topic: ARGH! Leak!  (Read 2575 times)
acbrock
  • USA, CA, Santa Monica
ARGH! Leak!
« on: January 10, 2024, 21:09:34 »
So I started my car this morning and let it run for about 15 minutes.  I needed to move it a slight bit so I can get better access to the door.  about 15 minutes in a noticed a leak near the Drivers door.  Since I my dash is not all together yet it was pretty easy to trace to the Oil Gage in the dash.  Since I have had these out to repair, any one have a good guess if, I just did not tighten the oil line into the gage or did I break that line?    Guess the question is I thought maybe I was a little rough on the line but when I got it back in I got a pressure reading.  Just curious if I could still get a pressure reading and have destroyed the line so it I needs to be replaced or just tightened?
Aaron
1966 230SL Automatic 717G Papyrus White "Minny"
Re: ARGH! Leak!
« Reply #1 on: January 11, 2024, 03:31:03 »
Depending on much was leaking out, it could just need to be snugged up.
Re: ARGH! Leak!
« Reply #2 on: January 12, 2024, 21:24:03 »
Aarons oil line.
acbrock
Re: ARGH! Leak!
« Reply #3 on: January 14, 2024, 19:12:32 »
Haha!  I wish!  I could have a fleet of Pagoda's if I had an oil line like that!
But.. I was going to get in and tighten it up today.  Should or Could I use any pipe thread stuff or liquid electrical tape to fill any Knicks in the metal?  Or is it a clean metal and if it leaks it is a replace the whole line?
A
Leester
  • USA, VA, Lorton
Re: ARGH! Leak!
« Reply #4 on: January 14, 2024, 20:17:14 »
On my 280SL I believe that is a steel line. Since I too am working on the instruments, I have fastened and unfastened that connection many time (10mm wrench if I recall). I think you would have to have been VERY rough with it to cause a break in the line but I suppose its possible. I think its more likely that you don't have it snugged up or possibly cross threaded it. Snugging mine up did not require much force with the wrench. I can hand tighten mine then just a tad more with the wrench and I can feel it bottom out.
I don't think you could patch the line but would have to replace if indeed the line is cracked.
If I recall that is a hard line that joins with a black, kind of plastic (forget what they call that stuff) line in the engine compartment. Is it possible you cracked or broke that?
Lee Backus
1963 220SE Cabriolet
acbrock
Re: ARGH! Leak!
« Reply #5 on: January 17, 2024, 22:43:32 »
Ok so finally had some time today... So read some old posts and pulled out the Tach to get to the back on the Instruments.  Removed then assembled the oil.  With a little wrench I got in there and tightened it up WAAAAAY more than I did the first time!  Ran it again and leak is gone!  Wahooo.  But now the tach won't work.  Pulled the tach and it is turned so I think I just again, did not tighten it down enough.    So I think I should be good.  Unfortunately when reading the old posts, I mixed up the 2 lines to the Cluster.  I thought the Oil was the fragile one, not the Temp.  So I might have killed that one.  It is cold here today and I am working outside so running it for about 3 minutes I registered no temp on the gage.  So either I killed it or I did not run it long enough.  Had a tiny leak on on of the hoses that I temp attached with a zip tie and that started leaking so I shut it all down.  Will clamp those hoses on tomorrow and let her run for a little while.
Thanks for the help!  Off to post on the Carpet Forum because I have an extra piece of carpet I cannot figure out!
GM
  • USA, CA, San Pedro
Re: ARGH! Leak!
« Reply #6 on: January 17, 2024, 23:10:29 »
The temp gauge line is filled with a gas, and if it leaks out the gauge won't work. Ask me how I know. 8)
You need to send it out (with the gauge) to get repaired.
Recommend Palo Alto Speedometer, Hartmut Mees is great. Also heard good things about North Hollywood Speedometer.
Good luck
« Last Edit: January 27, 2024, 21:36:43 by GM »
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
ejboyd5
  • Southold, NY
Re: ARGH! Leak!
« Reply #7 on: January 18, 2024, 13:19:57 »
Run it more than 3 minutes.  It might take more time than that to register.
acbrock
Re: ARGH! Leak!
« Reply #8 on: January 19, 2024, 03:01:31 »
will do it tomorrow!  Just have to secure the hoses again!  I will report back!
acbrock
Re: ARGH! Leak!
« Reply #9 on: January 27, 2024, 21:32:06 »
Ok took me a few more days than planned to get her running again.  Ran for about 10 minutes and the Temp Gage responded!  Whahooo.  Glad I dont need to replace.  All all Leaks are dry.  1 new leak at the connection of the Oil Line right after it gets into the engine compartment.  99.9% just need a 1/2 turn.  But overall a great day!  Off to wrestle with some carpets....
