Hey gang,
Thought I'd share my nightmare with your all.
Last weekend my "Lil Red Car" stranded me about 70 miles from home
. The transmission shifter linkage fell off the car, completely. And, since I had no parking brake, I had to lye under the car, while someone else sat in the driver seat with the brake applied, while I shifted it from reverse into driver. Very scarey. I did get home, thank God.
Anyway, I bought and received a transmission motor mount (and bellow) and 2 shifter bushings from Ray Paul (now at Bud's Benz). So, off I went Saturday to replace the mount, and reinstall the linkage rod. The transmission mount went pretty smooth. I didn't even have to remove that large triangle transmission mount plate to do it
. I was afforded enough access from the drive shaft (propeller shaft) access hole behind the transmission. Thanx to George Davis for the tip on lifting the tranny at the bell housing.
But, that's the only thing that went smooth. Since I had the car up on 4 jack stands, I figured I'd bleed the brake lines, adjust the brakes, fix the parking brake, lube the chassis and drive line, and, of course, reinstall the shift linkage rod.
Well, after 1.5 hours of toil, I gave up on the linkage rod [
!]. I tried every way to Sunday to figure out how to route the rod, but failed.
So, I went on to the brake lines. Well, pretty much MUD came out of the bleeder nipples. I bled 2 bottles of DOT3 fluid before it all came out clean. That was kind of disheartening :? !
Then, on to the chassis lube. I found what seemed to be 30 years of crud caked on to all the grease fittings and where the grease oozes out of each joint. After an hour of cleaning that, I noticed that all 8 of the flexible rubber sealing rings on the pivot joints for both left and right, upper and lower control arms are all damaged :x . All 8 - I couldn't believe it. That looks like a VERY PAINFUL repair! So, I finished up lubing everything up front.
When I got to the rear of the car, I noticed the seal between the differential case and the "Carrier for rear axle suspension" is all chewed up. What a freaky rear-end, anyway! What the heck is that thing, BTW, the "Carrier for rear axle suspension"? And, what does it do? I don't even think I lube'd the nipple behind that thing, I was probably crying by then :evil: .
Next, on to fixing the parking brake. I wanted to remove one of the rear rotors to expose the drum brake system. As soon as I read and realized that removing the caliper required disconnecting the brake line, and opening my now bled system I just about fainted :x . Fortunately, using the lug bolt (spherical flange bolt) I was able to peer into the drum and see tons of meat on the shoes. I was able to access the adjusting device and simply adjust the shoes until they made contact, then back off 2 clicks. So, the parking brake works now, without having to remove the rotor. That was cool
So, with about 18 hours of work, I successfully replaced the rear transmission and motor mount, lubed most of the chassis, bled the brakes, and adjusted the parking brake (which now works, thank God). And, in doing so, identified a good 60 hours of work I need yet to do before taking the car off the stands
I'm posting TONS of questions and cries for help. You'll see the forum loaded with my posts. I figured I'd post each issue seperately, so the threads can remain on topic, nad hopefully be helpful to someone else in the future.
Thanx for reading my sob story. And thanx for any help you'll be able to offer me - 'cause I sure need it
1971 280SL US Automatic
