Author Topic: Early style Power Window Motor Coupling - W111/W108  (Read 1974 times)
« on: January 15, 2024, 19:52:49 »
Finally back in stock with a new batch produced. These flexible couplings fit between the window motor and the gear head on first generation Mercedes power window set ups. NLA and not produced anywhere else. The rubber on most are starting to crack, harden and deteriorate as they are 60+ years old. These new ones have upgraded brass ends compared to the OEM plastic ends. These couplings fit on both door and quarter windows on the two door cars and all four doors on a sedan.
The early style power windows use motors with three wires and the switches are typically on the door panels. The motor casting is separate from the gearhead. See attachment.
NOTE: These couplings do NOT fit on the later versions starting around 1969. The later versions have a two wire motor and switches are typically on the console. The motor and gear head are the same casting and therefore no coupling is required.
Please PM if you have any interest and I can send installation instructions.
Thank you.
