Author Topic: Steering Box; the big round nut  (Read 1708 times)
Sens
  • Netherlands, North Brabant, Drunen
« on: January 16, 2024, 15:30:37 »
I would like to overhaul my power steering box; so far so good.
I managed to unscrew the big nut with an enormous wrench (55mm)  and with some heat it worked!
However the round nut with the 2 holes in it is more difficult to get loose.
I tried heat and two little pins, but not successful yet.
How do you guys do that? You made your own tool? Or a different procedure?
Thanks!
Halvor
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Steering Box; the big round nut
« Reply #1 on: January 16, 2024, 15:36:57 »
Do you think taking the 4 bolts out of the cover will help?  Mabe that has to be taken apart first.
« Last Edit: January 16, 2024, 16:29:02 by badali »
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
Sens
« Reply #2 on: January 16, 2024, 15:54:37 »
I did that before, but I have put them back in the house to have better grip.
Thanks!
BobH
« Reply #3 on: January 16, 2024, 15:55:25 »
i haven't read it, but does this help?
https://www.sl113.org/wiki/Steering/PowerSteeringBox
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Sens
« Reply #4 on: January 16, 2024, 15:59:53 »
Thanks you very much.
I have this paper printed out on my desk!
In the mean time I ordered this tool. Hope it will help.
dirkbalter
  • USA, CA, Corona
« Reply #5 on: January 16, 2024, 16:07:49 »
Take a look in the manual.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
BobH
« Reply #6 on: January 16, 2024, 16:10:35 »
Looks like that tool is exactly what you need!
UK delivered RHD
Blue soft top
Blue leather
Sens
« Reply #7 on: January 16, 2024, 16:15:34 »
Yes, indeed!
« Reply #8 on: January 16, 2024, 17:25:50 »
What is the problem you are trying to solve?
What do you expect to do in this overhaul that will fix the problem?
Sens
« Reply #9 on: January 16, 2024, 18:16:25 »
I had a leak at the bottum of the pump and bought a seal kit.
Now that the pump is out of the car I want to replace the seals, assemble it, do the necessary ajustments and put it back in the car.
« Reply #10 on: January 16, 2024, 20:40:36 »
That will be a good job done.  The page of the manual shared by dirkbalter seems to indicate that the entire disassembly may be documented in the MB manual.  Do you have any technical documentation/instructions?  I'm sure you can get a lot of help from experienced members.  This will be a good thread to follow.  Sealing up leaks is a common issue.  Take lots of pics for us!
What adjustments do you want to make?  Is it to reduce "play" or "slop" in the steering or some other adjustment?
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #11 on: January 20, 2024, 18:22:47 »
I had a leak at that top seal. I could not get that nut off, finally I ordered a rebuilt box.  Might consider that. Once I installed the rebuilt box, holy cow, my steering is so precise now. No play what so ever. I had been driving my SL for almost 20 years and did not know that you should not have play in your steering. What an improvement.
Robert Hyatt
Williamsburg, VA.
Sens
« Reply #12 on: January 20, 2024, 21:45:05 »
In the mean time the big 55mm nut is loose and so is the big round nut.
I used the new pin tool and some heat.
Good tools really made the difference!!
I just started the assembly!
Sens
« Reply #13 on: January 22, 2024, 15:27:32 »
I am struggling a little with the torques to set in the steeting box.
In the Technical Manual (first line) it says 0.69 to 0.86 in-lbs which is 0.08 Nm. That is just the bearing in its house I suppose.
The second line says 1.38 to 1.56 in-lbs (0.16 Nm) However in the drawing 1.4 to 1.6 Ft-lb is noted. (2 Nm)  That is another unit and a lot more!
Is that a mistake or am I mistaken???
dirkbalter
  • USA, CA, Corona
« Reply #14 on: January 22, 2024, 17:04:01 »
The torque of certain subassemblies are verified / adjusted prior to assembling the complete unit. Some of the torque values are very low and require special torque wrenches.
See attached,
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Sens
« Reply #15 on: January 22, 2024, 18:10:18 »
OK!
Thanks a lot; I will study this and set the toques correctly.
dirkbalter
  • USA, CA, Corona
« Reply #16 on: January 22, 2024, 18:16:48 »
If you PM me with an e-mail, I send you the repair section of the manual. (Unless you have it)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Sens
« Reply #17 on: January 22, 2024, 18:40:32 »
Thanks for the offer, but I have it.
I studied all pages, but not the first one with the torques.
Thanks for opening my eyes!
Halvor
