Author Topic: New Carpet Question.  (Read 1632 times)
LA280SL
  • USA, CA, PACIFIC PALISADES
« on: February 04, 2024, 04:48:24 »
I made a good push on installing the Heritage carpet kit today. The heat gun was the key to the 90 degree bends on the ends of the back wall section.
The parcel shelves have that sharp angle to deal with and I’m not certain the heat gun will get the job done.  For you that have conquered these pieces, do I use the heat gun, cut and trim along the seam, or is there another way.
Trying to post pictures but having issues.
Much appreciated!
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: New Carpet Question.
« Reply #1 on: February 04, 2024, 09:55:53 »
My friend at the upholstery shop uses steam.  Using a heat gun could singe or melt the material.  Steam will soften the material without damaging it.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
LA280SL
« Reply #2 on: February 04, 2024, 16:16:37 »
I have a pressure steam cleaner, might give it a try.
One question, I glue the back of the carpet and let it dry before warming it with the heat gun, which keeps the glue dry and tacky as required.  Wouldn’t the steam do the opposite?  I don’t think carpet would stay pliable enough to add glue after, then let it sit to get dry.
LA280SL
« Reply #3 on: February 04, 2024, 16:37:28 »
LA280SL
« Reply #4 on: February 04, 2024, 16:38:41 »
Other view
dirkbalter
  • USA, CA, Corona
« Reply #5 on: February 04, 2024, 16:59:56 »
That may not help you but the carpet kit I bought from Gaah, came with these corners cut and resewn. That made the installation easy. You may have to do something similar.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #6 on: February 04, 2024, 18:12:21 »
Glue it then use steam while stretching it over.  That is the way I have seen him work the material.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2025 E53 AMG Sedan
LA280SL
« Reply #7 on: February 04, 2024, 20:17:01 »
Thanks Dirk and Brad. I’m going to figure out my path this afternoon.
