Author Topic: LED Light Bulbs  (Read 1925 times)
alchemist
  • USA, NY, GRAND ISLAND
LED Light Bulbs
« on: February 05, 2024, 21:52:37 »
I have 1967 230SL and I am considering replacing the backlights with LED bulbs to get more intense light. Would this replacement add more load on the wiring system and the fuse box? Is there any precautions I should take before this replacement?
Re: LED Light Bulbs
« Reply #1 on: February 05, 2024, 23:40:51 »
"Backlights"
You mean the back lighting of the instrument cluster?  Or, the backing (reversing) lights in the taillight assembly?
Well, either way, LEDs use less power so they should be putting less load on the system.
Quite a lot of discussions have occurred on LED lighting, so there is a lot you can learn using our search feature.
alchemist
Re: LED Light Bulbs
« Reply #2 on: February 09, 2024, 18:54:51 »
I intend to replace the B9 small bulbs for the backlight only. The reason is that the original bulb does not give out intense light which is hard to see by traffic behind us. Thanks for your contribution.
Re: LED Light Bulbs
« Reply #3 on: February 09, 2024, 20:48:03 »
OK, so backlight = taillight.  Do you call your headlight a frontlight?
Did you try the Search feature?  Here's just one sample discussion I found.  There are many more, plus details in the Tech Manual for Full Members.
https://www.sl113.org/forums/index.php?topic=22863.0
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
Re: LED Light Bulbs
« Reply #4 on: February 09, 2024, 20:55:51 »
Every single bulb I changed to LED, dash instruments, heat vent control etc...
1964 230SL
lagolag
  • Sweden, Västra Götaland, Askim
Re: LED Light Bulbs
« Reply #5 on: February 10, 2024, 22:31:58 »
I’ve done it and its not causing any problem.
230SL 1967 since July 2021
SL55 AMG 2003 since July 2008
Suzuki Cappuccino 1995 since May 2006, Sold
Paul99
  • United Kingdom, England, Hampshire UK
  • 230 SL White. 1966.
Re: LED Light Bulbs
« Reply #6 on: February 13, 2024, 09:30:05 »
I think the dash charging light needs to be an old school non LED so that it ignites the charging system. Could be wrong but not sure an LED will do that.
yves
  • France, Poitou-Charentes
Re: LED Light Bulbs
« Reply #7 on: February 13, 2024, 15:00:21 »
I agree with Paul advice, I replaced some months ago that light with a LED with a resistance soldered and an autoelectrician took it away and put an old bulb.
The dash charging light is correct now....!
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
Re: LED Light Bulbs
« Reply #8 on: February 13, 2024, 16:05:24 »
I  tried a search first but couldn't find anything - My question: has anyone ever tried replacing European SL headlight bulb with an LED?
JB
JB; 1965 German market SL, Rot Met 571, Summary Code 213 Interior
Sead
Re: LED Light Bulbs
« Reply #10 on: February 13, 2024, 17:55:32 »
there are instructions how to solve this. my charging light is also LED
1964 230SL
Re: LED Light Bulbs
« Reply #11 on: February 14, 2024, 12:01:08 »
I can't wait when the LED retrofitted headlight bulbs are legal in the EU. It is just now some types for some cars.
Sead, you are closer to this - if you hear any good news on this topic, please shout.
