Author Topic: Which electronic ignition is better  (Read 1806 times)
CJHenderson
  • USA, AR, Benton
« on: February 08, 2024, 16:06:08 »
Which electronic ignition is better for a 280SL/8 programable or non-programable? My old distributor is worn out and the cost of a rebuild will almost be as much as changing over.
1950 MG-TD
Re: Which electronic ignition is better
« Reply #1 on: February 08, 2024, 16:11:59 »
I am a happy user of bluetooth programmable 123ignition with immobilizer function. Could not compare to other solutions, I am afraid.
dirkbalter
  • USA, CA, Corona
« Reply #2 on: February 08, 2024, 16:15:47 »
I agree with Pawel. If you have the US - emissions system installed, you will have to go programable to make it work imo.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #3 on: February 08, 2024, 17:26:46 »
CJ, if your distributor is worn, it's not a question of an electronic ignition or not, it's either rebuild/replace the distributor (then choose an electronic insert) or simply get a 123.
I've had two -051 distributors rebuilt (long story) but that was when it was way less costly AND parts were readily available. I don't think that's the case now. So, back about 15 years ago, I had the distributor rebuilt, junked the old Crane XR700 and installed a Pertronix. Two I knew then were rebuilding them: Dr. Benz here (who did one) and Glenn Ring out of New York (who did the other). Glenn ran out of parts some years ago and I don't think he's doing it anymore...
If something were to cause me to do this again today, in a heartbeat I'd get the 123 distributor, and the programmable one at that.
« Last Edit: February 08, 2024, 17:33:18 by mdsalemi »
CJHenderson
  • USA, AR, Benton
« Reply #4 on: February 08, 2024, 19:41:49 »
Will I need to get an engine control module since I'm upgrading my system?
1950 MG-TD
dirkbalter
  • USA, CA, Corona
« Reply #5 on: February 08, 2024, 20:14:20 »
Aside from the distributor, what are you planning on upgrading?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
CJHenderson
  • USA, AR, Benton
« Reply #6 on: February 08, 2024, 20:27:39 »
Outside of the required hardware for the distributor such as carbon plug wires and coil. But I have no clue about the ECM except where to plug it in, not to mention it's an OEM.
1950 MG-TD
« Reply #7 on: February 08, 2024, 22:57:34 »
These cars have no ECM. The 123 has all electronics inside, no need to do anything else to the car except drop in the 123 and connect the few wires, set the timing and you're done.
Pinder
  • USA, NJ, Edison
« Reply #8 on: February 08, 2024, 23:07:19 »
I agree with everyone here who mentioned the 123 ignition. It works great. I too got the one with bluetooth. it syncs to my iphone and It has a nice display showing the tachometer, you can create your own curves. Its a good quality unit. no regrets. I keep my old distributor incase the next custodian wants to return back to original.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
« Reply #9 on: February 09, 2024, 00:36:01 »
Unless something is totally different with the 123 distributor (those who have it, please chime in here!) you want solid wires (copper core) not carbon. The OEM plug connectors have some resistance for radio suppression.
Plenty written about plugs, wires and connectors in other threads.
« Reply #10 on: February 09, 2024, 06:59:14 »
Coil resistance above 1 Ohm, this is what they require for 123ignition.
MarkCan
  • Canada, Ontario, Mississauga
« Reply #11 on: February 09, 2024, 15:37:34 »
My vote goes to the 123 ignition system. Here is the installation video; https://youtu.be/Z39UwaFiXaE?si=LlLMqCJfT9dCd8v0
You can also send your old distributor to Dr. Benz here and have it fully restored. Dan will not only rebuild, he can also properly setup and test the unit (using factory equipment) before shipping it out.
« Reply #12 on: February 09, 2024, 19:44:19 »
Stay clear of carbon wires.
CJHenderson
  • USA, AR, Benton
« Reply #13 on: February 09, 2024, 20:15:11 »
Thanks Doc, glad that I didn't order it.
1950 MG-TD
« Reply #14 on: February 09, 2024, 20:58:48 »
Here in Europe I found Beru 7MM, e.g.:
https://swiece-zaplonowe.pl/przewody-wn/17768-beru-copper-cable-0300800023-7mmsblack.html
I am posting as it may not be easy to find copper leads.
« Reply #15 on: February 09, 2024, 21:35:00 »
560SL's also use metal wires so they should be available. K&K has the proper ignition wires - Tim and I worked on that to get them right.
MarkCan
« Reply #16 on: February 10, 2024, 00:50:27 »
I second that, K&K Manufacturing is the place to go for ignition cables in North America.
https://www.kkmfg.com/
I purchased several sets from different suppliers and none were close to what K&K delivered - proper M127-130 cables.(1K ohm)
As for the Beru, European and N.American cables are two different animals. Sets I purchased in US were all 5k ohms.
