Author Topic: Warm Running Device  (Read 2340 times)
dpreston Virginia
  • USA, VA, Salem
Warm Running Device
« on: February 10, 2024, 23:05:18 »
My 69 280SL has been running rich and quickly fouls the spark plugs. I have gone through the linkage tour, check cold start valve (working perfect), replaced injectors and now I removed the Warm Running Device. It was thoroughly stuck.
I have cleaned it and hit it with PB blaster, then grease I have finally gotten it to move by hand but not to allow it to move freely enough for the plunger to move it. Do I need to take it completely apart? If so how do I do that or how to I free it up?
Photos show the movement I can pushing the valve open and close.
Thanks for any help to fix my WRD.
David Preston
190SL 1960 Sold
280SL 1969
280SE 1969 cabriolet
Vette 67
Porsche 912 67
Re: Warm Running Device
« Reply #1 on: February 11, 2024, 01:33:02 »
You're a Full Member, anything in the Tech Manual?
dpreston Virginia
  • USA, VA, Salem
« Reply #2 on: February 11, 2024, 02:11:07 »
Not how to take it apart and get it working.
190SL 1960 Sold
280SL 1969
Vette 67
Porsche 912 67
« Reply #3 on: February 11, 2024, 10:30:53 »
I think taking it apart is, basically, unscrewing two screws and parts you get are shown here: https://www.sl113.org/wiki/Engine/WarmRunningDevice
How to get it working - I think it is about freeing the valve if it is stuck, making sure that the thermostat is working and then adjusting it with two types of shims. Technical Manual covers all if it in essence.
As for freeing up the valve:
https://www.sl113.org/forums/index.php?topic=14134.msg96068#msg96068
https://www.sl113.org/forums/index.php?topic=14271.msg97165#msg97165
As for checking if the thermostat is working, e.g. here:
https://www.sl113.org/forums/index.php?topic=30847.0
Use a pot or kettle, thermometer and measure extention of the thermostat pin
AS for adjusting:
Oval shims regulate fuel mixture during warm up - more shims, richer mixture.
Round shims regulate time when WRD is working (depends on temperature) - more shims means longer work of WRD.
Search on the forum will point to a lot more materials.
Pinder
  • USA, NJ, Edison
« Reply #4 on: February 11, 2024, 16:32:51 »
I found this video to be a good explaination
https://www.youtube.com/watch?v=F6sxlOFmoYw
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
dpreston Virginia
  • USA, VA, Salem
« Reply #5 on: February 11, 2024, 19:49:47 »
What a great how to video! Thanks for sharing!
190SL 1960 Sold
280SL 1969
Vette 67
Porsche 912 67
Pinder
  • USA, NJ, Edison
« Reply #6 on: February 11, 2024, 21:13:33 »
To free up the mechanism reemove the air filter, (should screw off) and spray your favoirte WD40 or equivelant to free it up so it moves smoothly, sea foam etc spray it every hole.
« Reply #7 on: February 11, 2024, 21:53:01 »
Maybe also:
- during the kettle test, you can just blow through the device to see if the thermostat is closing the air
- when you are putting it back together, it is good to apply some sealant between thermostat and its housing; the sticking of the air valve comes often from coolant dripping down there where the valve is and leaves residue that makes the valve and plunger stuck
dpreston Virginia
  • USA, VA, Salem
« Reply #8 on: February 12, 2024, 19:37:35 »
Took the valve completely apart and lightly sanded the inside of the body and the valve. Then added some grease. Reinstalled and the car is running well.
Thanks for all the help especially Joe Alexander. What a great community.
190SL 1960 Sold
280SL 1969
Vette 67
Porsche 912 67
« Reply #9 on: February 12, 2024, 20:32:18 »
dpreston,
That's great!  Good work.  I have two questions.
... lightly sanded the inside of the body and the valve.
Why?
Where?
dpreston Virginia
  • USA, VA, Salem
« Reply #10 on: February 12, 2024, 20:41:30 »
I sanded the air valve and air valve housing with 800 grit paper. And then put grease in the housing to ensure smooth easy movement.
David
Photo of these parts are in technical manual at: https://www.sl113.org/wiki/Engine/WarmRunningDevice
190SL 1960 Sold
280SL 1969
Vette 67
Porsche 912 67
« Reply #11 on: February 12, 2024, 20:45:52 »
But, nothing moves in the hosing.  It's just a place for the thermostat to sit and be affected by water temperature.
« Reply #12 on: February 12, 2024, 20:46:49 »
Oh, you meant air valve housing.  Duh!  Sorry.
