Author Topic: Power steering pump seal  (Read 1751 times)
sens
  • Netherlands, North Brabant, Drunen
« on: February 12, 2024, 21:26:06 »
I am changing the seals of my power steering pump.
What would be the best way to get the seal out on the shaft with the pully?
From the outside or first get the shaft out?
Do I run into a lot of problems if I try to get the shaft out?
Thanks a lot!!
Halvor
Halvor Sens
sens
Re: Power steering pump seal
« Reply #1 on: February 14, 2024, 23:05:34 »
Finally the seal is easy to remove with a screw driver as long as you pay attention not to damage the shaft.
Halvor
Halvor Sens
