Author Topic: 123 programable distributor yellow wire  (Read 1361 times)
CJHenderson
  • USA, AR, Benton
« on: February 13, 2024, 14:16:13 »
Where does the yellow wire attach to? I know where the red, black, & blue goes to.
1950 MG-TD
Re: 123 programable distributor yellow wire
« Reply #1 on: February 13, 2024, 15:21:23 »
I think I saw on some of the applications that it may be for curve change (signal - curve X, no signal - curve Y) or for D-jetronic connection on some other, like in the link.
 https://123ignitionusa.com/wiring-diagrams/
dirkbalter
  • USA, CA, Corona
« Reply #2 on: February 13, 2024, 15:21:54 »
I will check later but don't recall having a yellow wire. What 123 did you buy?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
CJHenderson
  • USA, AR, Benton
« Reply #3 on: February 13, 2024, 16:40:15 »
Got it from SLS. It's a 123/Tune 6-R-V-M Produced in the Netherlands.
1950 MG-TD
dirkbalter
  • USA, CA, Corona
« Reply #4 on: February 13, 2024, 18:04:46 »
you have a different one and from what I see, the yellow wire is to select different curves.
Thake a look at their manual:
https://123ignitionusa.com/content/123_tune_manual.pdf
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
123ignitionusa
  • USA, OH, Columbia Station
« Reply #5 on: February 13, 2024, 18:08:09 »
The yellow wire is on the TUNE PC programmable distributor along with a Red, a Black, and a Blue. The yellow is connected to a power source and will activate curve two when switched on, in the pc programmable distributor.
Hope this helps
« Reply #6 on: February 14, 2024, 22:48:15 »
Hello 123ignitionusa,
So, are you a 123 distributor distributor?  Ha!  Sorry, couldn't help myself.  If you're a vendor, you can register as such and post in the vendor forum.
CJHenderson
  • USA, AR, Benton
« Reply #7 on: February 15, 2024, 11:22:32 »
Not a vendor.
1950 MG-TD
