Author Topic: Clock intermittently working - FIXED  (Read 2239 times)
awolff280sl
  • USA, FL, Sarasota
« on: February 14, 2024, 22:19:08 »
I got lucky. Clock (quartz) was working intermittently, running for a few hours, stopping for a few hours, then running again. 12v constant and ground both good at the Bakelite connector. I was prepared to open up the clock and poke around. Luckily before I got into trouble, I found that the 2 tiny nuts holding the white plastic connector onto the back of the clock were not tight. I tightened down those nuts and the clock has been running well since.
In case this helps someone.
cl
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
Re: Clock intermittently working - FIXED
« Reply #1 on: February 15, 2024, 00:33:35 »
..I found that the 2 tiny nuts holding the white plastic connector onto the back of the clock were not tight. I tightened down those nuts and the clock has been running well since. In case this helps someone..
thanks Andy, thats encouraging. My clock has been intermittent for about a year now and hopefully I'll be as lucky as you were. thanks,, charles
awolff280sl
  • USA, FL, Sarasota
« Reply #2 on: February 15, 2024, 02:26:35 »
please report back
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Bill
  • USA, CA, Fair Oaks
« Reply #3 on: February 27, 2024, 20:41:57 »
I had to remove and disassemble my clock. It had a burned out diode which needed replacement.,
