Author Topic: How to free seized drums (230SL)  (Read 1659 times)
NZ230
  • New Zealand, Canterbury, Christchurch
« on: February 18, 2024, 23:46:13 »
Hello I continue to work on my 65 barn find 230SL which the wheels are seized
How do I free the rear drum brakes? There are two nuts on the inner side of the wheel am I to turn them inwards (ie the one that’s at the front turns counter clockwise and the one that’s at the rear turns clockwise) in order to slack off the drum?
Hemal
Re: How to free seized drums (230SL)
« Reply #1 on: February 19, 2024, 06:50:23 »
Basically, yes.  See details in this thread.
https://www.sl113.org/forums/index.php?topic=37191
« Last Edit: February 21, 2024, 21:06:33 by rwmastel »
ctaylor738
  • USA, VA, Falls Church
« Reply #2 on: February 21, 2024, 16:50:58 »
IIC, the fittings are cams so it doesn't matter which direction they are turned.  You need to find the "low spots."
Cheers,
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
ctaylor738
« Reply #3 on: February 24, 2024, 18:37:28 »
Thinking about this, it may not be a problem with the adjusters.  The shoes can be stuck from rusted cylinders or a plugged lines or hoses.  Suggest you open the bleeder.  If that doesn't help, disconnect the metal line from the cylinder.
Also check that the parking brake cable isn't sticking.
Good luck,
CT
Chuck Taylor
1963 230SL #00133
Falls Church VA
