Author Topic: Steering wheel rattle from bearing  (Read 1649 times)
col320ce
« on: February 20, 2024, 05:55:11 »
I'm getting a rattle that I think is coming from within the steering wheel. I think it might be the bearing that I'm holding that is rattling. Am I missing a spring or something in my assembly to stop it from rattling? When it's put back together there is some movement of the chrome horn part which means that it is not appearing to compress the bearing allowing it to rattle.
This is the 1965 250SE cp but I assume the pagoda should be the same.
And thoughts?
« Last Edit: February 20, 2024, 06:26:58 by col320ce »
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
WRe
Re: Steering wheel rattle from bearing
« Reply #1 on: February 20, 2024, 07:11:07 »
I had a rattle coming from worn rubber grommets between horn contact ring: https://www.sl113.org/forums/index.php?topic=33714.msg246482#msg246482.
...WRe
col320ce
« Reply #2 on: February 23, 2024, 00:19:40 »
Thanks ... Let me investigate...
Col
1964 230SL
1965 250SE coupe
JedinDetroit
  • USA, MI, Harrison Twp
« Reply #3 on: March 12, 2024, 04:20:26 »
Steering coupler is well known to rattle “up” the column when its bushings fail.
col320ce
« Reply #4 on: March 12, 2024, 10:37:33 »
Steering coupler was replaced a few years ago but I'll check that thinks haven't changed with it.
Col
1964 230SL
1965 250SE coupe
