Author Topic: Soft top tension cables  (Read 1751 times)
Savakis
  • Greece, Central Macedonia, THESSALONIKI
« on: February 20, 2024, 20:46:14 »
Hello, I would like to make sure that the soft top tension cables will be fitted correctly.
Please check the attached pictures and kindly comment about the cable's routing.
Does it look properly fitted?
Best regards,
Savvas
dirkbalter
  • USA, CA, Corona
Re: Soft top tension cables
« Reply #1 on: February 20, 2024, 23:18:24 »
The cables are fed through the soft-top canvas. Are you aware of that?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #3 on: February 21, 2024, 15:36:22 »
It is also important how the wires go down the pillar through their holes and channels:
https://www.sl113.org/forums/index.php?topic=30029.msg217515#msg217515
One of the important topics I learned: do not ignore the elastic straps. Without them soft top will not work properly. Material in pdf enclosed.
Finally: it is easy to pull the big springs by hand (wearing a thick glove to protect your skin) when you set the rear bottom part of soft top at 45deg angle and support it or have someone hold it. You do not need anything elaborate to pull it then.
Savakis
« Reply #4 on: March 01, 2024, 20:51:01 »
Thanks for your response, I appreciate.
Savakis
« Reply #5 on: March 01, 2024, 20:55:52 »
Many thanks!
Savakis
« Reply #6 on: March 01, 2024, 20:59:35 »
Savakis
« Reply #8 on: March 01, 2024, 21:48:56 »
Savakis,
From the comments and links, did you learn all you need to know?
