Author Topic: Gear box carrier plate  (Read 1434 times)
Sens
  • Netherlands, North Brabant, Drunen
« on: February 22, 2024, 22:18:58 »
Hello Pagode friends!
I have put the engine back in my Pagode and all went well!
I was going to mount the gear box carrier plate with the 12 M 10 bolts.
Quite an important plate since it supports part of the weight of the engine/ gearbox.
However I noticed that 4 of the bolts  had a bad thread and I was not able to tighten them. The steel is in good shape; not rusted or anything.
They must have been over tightened in the past I guess. I tried some new bolts, but same result.
Would a helicoil be the best solution to solve this problem?
Thanks for your advice!
Halvor Sens
Kevkeller
  • USA, HI, Honolulu
Re: Gear box carrier plate
« Reply #1 on: February 22, 2024, 22:57:59 »
Did you try a rethreader or a tap in the nut ends?
1970 280 SL
Sens
« Reply #2 on: February 22, 2024, 23:05:59 »
No, I did not yet.
But would that "repair" the thread?
I am afraid I miss some metal in the tread.
I do have that M10 tap, but do you think that could help me?
It would be by far the easiest solution.
dirkbalter
  • USA, CA, Corona
« Reply #3 on: February 22, 2024, 23:07:59 »
If it is the bolts, you can just get new bolts. Cheap. In my case, the nuts that are tacked to the tunnel were bad and after re-tapping them, they would not allow me to apply torque without stripping. I had to replace 4 of them.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Sens
« Reply #4 on: February 22, 2024, 23:12:18 »
Thanks for your comment!
In my case the problem is caused by 4 nuts, like in your Pagode, Dirkbalter!
And yes, I tried new bolts.
Putting new nuts is looks complicated; how are they accessible?
The helicoil solution could be a good alternative, I guess.
dirkbalter
  • USA, CA, Corona
« Reply #5 on: February 22, 2024, 23:20:08 »
They run along the left and right side of the tunnel bottom . With the carpet and insulation out, you should see them from inside the cabin. I was surprised how flimsy they were. After cutting them out, I tack welded regular M10 hex nuts in place, using the trans mount plate as a reference.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Sens
« Reply #6 on: February 22, 2024, 23:23:42 »
Oh! That is excellent news!
So they are accessible from the cabin after removal of the carpet and insulation! Fantastic!
That is a very good solution!
Thanks!
Pinder
  • USA, NJ, Edison
« Reply #7 on: February 22, 2024, 23:27:28 »
could you use a larger tap and retap them?
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Sens
« Reply #8 on: February 22, 2024, 23:31:21 »
Yes, but according to dirkbalter these are flimsy nuts, so making a bigger hole might be risky.
I think tacking new nuts in would be the best solution!
Pinder
  • USA, NJ, Edison
« Reply #9 on: February 23, 2024, 03:06:36 »
That is true.  But maybe worth a try and if it fails then you can remove the carpet.
Regards
dirkbalter
  • USA, CA, Corona
« Reply #10 on: February 23, 2024, 03:08:03 »
These are the nuts I am talking about. You have to judge for yourself, but I had a hard time with the original ones applying sufficient torque without stripping them.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Pinder
  • USA, NJ, Edison
« Reply #11 on: February 23, 2024, 03:11:40 »
Yes, probably best to take up the carpet so you have the same nut size.
Kevkeller
  • USA, HI, Honolulu
« Reply #12 on: February 23, 2024, 04:31:59 »
A rethreader is like a tap but the threads try to reshape the threads rather than cutting the threads.
https://a.co/d/2NV8geu
I’d try that first.
1970 280 SL
WRe
« Reply #13 on: February 23, 2024, 06:32:58 »
one of my nuts which is tacked to the tunnel was also bad. As a quick solution I used a longer screw with an additional nut ontop to solve the problem.
Later I removed the flimsy nut and used the original screw with a new nut, although, as in the first case, this required a helping hand to hold it.
...WRe
« Last Edit: February 23, 2024, 06:38:30 by WRe »
« Reply #14 on: February 23, 2024, 07:42:46 »
I think replacing by tack welding new nuts is the best solution.
I suppose this also tells us these bolts really don't need to be tightened all that much.
« Reply #15 on: February 23, 2024, 09:30:48 »
Buy yourself a time-cert kit and do what any professional would do.
https://www.timesert.com/
Sens
« Reply #16 on: February 25, 2024, 19:41:22 »
I removed 4 bad nuts and replaced them by new ones tag welded to the floor.
Problem solved!
Thanks a lot for your support!
Halvor
