Author Topic: Engine position  (Read 3347 times)
sens
  • Netherlands, North Brabant, Drunen
Engine position
« on: February 26, 2024, 11:41:37 »
I replaced the engine mounts on my 250SL and it was about time to do that!!
The gear box mount was still is very good shape.
The new mounts are about 15 mm higher compared to the old ones.
I am a little worried about the engine height with respect to the hood clearance.
I attached some pictures of what I measured.
It looks the engine is not horizontal at all, but maybe that is OK.
Kevkeller
  • USA, HI, Honolulu
Re: Engine position
« Reply #1 on: February 26, 2024, 12:44:52 »
You probably want to change the suspension to body mounts also. I believe they will raise the body up in relation to the engine.
1970 280 SL
sens
Re: Engine position
« Reply #2 on: February 26, 2024, 12:55:37 »
Yes, I think you are probably right.
You mean the rubber subframe mounts?
yves
  • France, Poitou-Charentes
Re: Engine position
« Reply #3 on: February 26, 2024, 13:36:45 »
Hi SENS  here is the measure on my 280 . If it can help ?
 3.8 mm
sens
Re: Engine position
« Reply #4 on: February 26, 2024, 13:49:48 »
Thanks Yves!
Helps a lot!!
Your 38 mm compared to the 47 mm in my case means the engine is 1 cm higher!
yves
Re: Engine position
« Reply #5 on: February 26, 2024, 13:59:33 »
My motor rubber mounts are new ....! 2000 km
UJJ
  • USA, CA, Grass Valley
Re: Engine position
« Reply #6 on: February 26, 2024, 16:12:54 »
Also make sure you have the spacer/washer correctly installed at the transmission mount. It will lower the front of the engine.
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
sens
Re: Engine position
« Reply #7 on: February 26, 2024, 17:03:37 »
Excellent suggestion Urban.
I will buy one and put it in place!
Re: Engine position
« Reply #8 on: February 26, 2024, 19:46:54 »
Yes, that's what Kevin is talking about.  If your subframe mounts are collapsed, then new ones will "raise up" the body from the subframe & engine.  I assume there would be a measurement that could be made with everything in place to learn if new mounts are needed.  I started a new thread in the Body sub-forum to find out.
https://www.sl113.org/forums/index.php?topic=37807.0
Re: Engine position
« Reply #9 on: February 26, 2024, 20:24:06 »
I've been reading old threads about subframe mounts.  Some smart people said if you're doing engine, transmission, and subframe mounts, then you should replace the rear axle mount and swing arm bushings as well.  This helps align the drive shaft and prevent destruction of the flex disk!  And, it fixes everything you should need to have a tight, smooth ride.  No weak spots.  So, you start working to fix one problem and you end up fixing five or six!  We should all be used to that, right?  ;)
sens
Re: Engine position
« Reply #10 on: March 08, 2024, 19:02:59 »
Job done!
I removed the old mounts and they were more than dead.
I used a spring clamp to keep tension on the spring. The mount on the drivers site went pretty easy, the other one was a little more difficult, but with a piece of wood between the case and the sub frame it was absolutely doable. I put a jack under the wooden beam, pushed it upwards and that gave me enough space to exchange the mount. This  process is safe and controllable.
The result was that I have 1 cm more clearance to the hood.
I also replaced the gear box support and added a 5 mm spacer. That gave even more clearance to the hood.
Problem solved!!!
Thanks for all your support!!!
Halvor
« Last Edit: March 09, 2024, 08:08:28 by Sens »
Re: Engine position
« Reply #11 on: March 08, 2024, 23:27:46 »
..., but with a pice of wood between the case and the sub frame it was absolutely doable.
Congratulations Halvor!  It's so satisfying to get it done, right?
What is the "case" you reference above?
The result was that I have 1 cm more clearance to the hood.  I also replaced the gear box support and added a 5 mm spacer. That gave even more clearance to the hood.
When adding spacers or shims, keep in mind that professional engineers designed it so there would be a straight line through the engine, transmission, drive shaft, and differential.  One common plane for everything.  So, be cautious that you're not tilting part of the equation.
sens
Re: Engine position
« Reply #12 on: March 09, 2024, 20:52:26 »
Hi Rodd!
I meant body in stead of “case”. Sorry…
I am aware of the straight line I have to follow. I plan to change the rear axle rubbers soon; then I will measure the “plane”, as you say.
Thanks for your suggestion!
Leester
  • USA, VA, Lorton
Re: Engine position
« Reply #13 on: March 10, 2024, 00:10:55 »
It looks to my eyes like the top of the valve cover is 17mm above the straight line across the front fenders. Fortunately mine is slightly less but does anyone know what the maximum height of the top of the valve cover can be before it makes contact with the hood?
Lee Backus
1963 220SE Cabriolet
sens
Re: Engine position
« Reply #14 on: March 10, 2024, 07:22:14 »
Hi Leester!
The bottum of the wood is resting on the 2 fenders, so that is the place to read your measurement: 37 mm.
Hope this helps.
Leester
  • USA, VA, Lorton
Re: Engine position
« Reply #15 on: March 10, 2024, 15:03:55 »
Thanks for the clarification Halvor. Like the rest of me, my eyes are performing less and less reliably!
Lee Backus
UJJ
Re: Engine position
« Reply #16 on: March 10, 2024, 15:25:31 »
I had to add a 3mm spacer washer to the transmission mount in order to get it a straight line. Also, if this is too low you may not be able to remove the valve cover.
Urban Janssen
Grass Valley, CA
173 anthracite grey
Re: Engine position
« Reply #17 on: March 12, 2024, 15:22:33 »
FYI, I just started a line of motor mount inserts that fit under the mounts to keep them from collapsing. Mostly sold 190SL sets but have the tooling for the 113 mounts. I'll post something in the next day or so in the commercial section.
sens
Re: Engine position
« Reply #18 on: March 12, 2024, 17:27:26 »
Could you tell me where exactly you measure the straight line?
dirkbalter
  • USA, CA, Corona
Re: Engine position
« Reply #19 on: March 12, 2024, 19:10:22 »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
sens
Re: Engine position
« Reply #20 on: March 12, 2024, 21:19:01 »
Thanks!
