Author Topic: Fuel pump port question  (Read 2316 times)
WhiteBlue
  • Australia
« on: February 28, 2024, 05:40:32 »
Hello can anyone help me identify this port on a short Bosch fuel pump please? Also should it have a copper crush washer on its screw ?
Thank you
 Michael
Mike WhiteBlue
WRe
Re: Fuel pump port question
« Reply #1 on: February 28, 2024, 08:46:21 »
this connection is the bypass connection. The bypass system prevents that vapor bubbles from the fuel tank through the entire fuel system. The vapor bubbles are  pushed back to the fuel tank through this bypass connection, which has a T-piece with the fuel return line.
The new pumps were installed without connection from the bypass to the fuel tank. The bypass connection on the fuel pump was closed blindly with a screw and a copper washer, see https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/47-fuel-tank/247000-p--234 and workshop manual 07-11.
Fuel pumps with connected bypass system don't have a gas hole in the overflow valve in the injection pump. Therefore this overflow valve has to be controlled when replacing an injection pump as well an electric fuel pump.
...WRe
WhiteBlue
  • Australia
« Reply #2 on: February 28, 2024, 11:13:14 »
Many thanks!
Mike WhiteBlue
