Author Topic: Soft top seals  (Read 2072 times)
Savakis
  • Greece, Central Macedonia, THESSALONIKI
Soft top seals
« on: March 01, 2024, 21:18:15 »
Hello, I ordered a new soft top and the supplier sent a pair of seals pictured in the attachment.
Would anybody help here?
I am wondering how to fit them...
In my old soft top it seems that the seals were glued under the top along the side edges -just like the attached picture shows.
Is this how to do it?
The problem is that in the frame there is a metal piece bent downwards, which protrudes just above the window. That metal is pressing the seal and creates a curved shape in the soft top's cloth...
Re: Soft top seals
« Reply #1 on: March 01, 2024, 21:53:24 »
Savakis,
You'll find a lot of information using the Search function.  After some self-education, you'll either have your answer or you'll have more detailed specific questions (regardless the topic of the day).
Savakis
Re: Soft top seals
« Reply #2 on: March 02, 2024, 05:06:09 »
Savakis,
Hello and thanks for your answer. I did this before asking, I typed "soft top seals" and nothing came up... If you do it now only my post appears.
BobH
Re: Soft top seals
« Reply #3 on: March 02, 2024, 09:24:08 »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
Re: Soft top seals
« Reply #4 on: March 02, 2024, 13:45:13 »
Yes to your question, you glue to the headliner of the top, and place the seals as close to the top stitching along the rain bead. This should clear the top frame. The propose of the two seals is to touch the top frame along the top of windows to seal out wind and rain.
Robert Hyatt
Williamsburg, VA.
Re: Soft top seals
« Reply #5 on: March 02, 2024, 16:56:46 »
You have to make sure that the elastic/fabric stripes work properly and raise the middle bow when folding the soft top. If they do not work (e.g. because they are old and lost their elasticity) the rubber seals will crack.
Re: Soft top seals
« Reply #6 on: March 03, 2024, 05:50:19 »
I just searched this sub-forum and got 3 pages of threads.  Something is amiss.
Savakis
Re: Soft top seals
« Reply #7 on: March 04, 2024, 07:06:25 »
Many thanks, I appreciate!
Savakis
Re: Soft top seals
« Reply #8 on: March 04, 2024, 07:07:21 »
Savakis
Re: Soft top seals
« Reply #9 on: March 04, 2024, 07:10:30 »
Thanks for your advice, that was really helpful.
Savakis
Re: Soft top seals
« Reply #10 on: March 04, 2024, 07:12:16 »
Many thanks Robert, good to know!
Re: Soft top seals
« Reply #11 on: March 04, 2024, 12:19:25 »
You have to make sure to select "Entire Forum". And you do not need to thank each individual contribution  ;)
