Author Topic: Gammatronix Electronic Ignition  (Read 829 times)
Jordan
  • Canada, ON, Jordan
« on: March 02, 2024, 15:02:02 »
Curious if anyone has fitted a Gammatronix electronic ignition system to their car?  Did a search but nothing came up.  They seem like a reasonably priced alternative to the conventional ignition system. I understand that these are being used by some early Porsche owners, both 6v and 12v cars.
https://gammatronixltd.com/epages/bae94c71-c5b6-4572-89a1-e89006e78fbe.sf/en_GB/?ObjectPath=/Shops/bae94c71-c5b6-4572-89a1-e89006e78fbe/Categories/Category3
Marcus
66 230SL  Euro 4 speed
Re: Gammatronix Electronic Ignition
« Reply #1 on: March 02, 2024, 15:51:15 »
Marcus,
While the price point seems inexpensive (under £30) understand that it does NOT eliminate points (at least it doesn't look that way from their information) which is something that the well known and proven Pertronix does, or even the Crane XR700.
These have been talked about for many years. The Pertronix uses a Hall effect pickup inside the distributor activated by a magnet ring you place on the distributor shaft. The Crane uses a shutter wheel and an optical sensor. It's always been said that either of these devices won't make up for a worn distributor so best not to try and correct distributor problems with one; ensure your distributor is "up to snuff" as they say before fitting one.
Of course if you have some kind of ignition issues AND your distributor is worn that 123 distributor replacement seems to be the universal choice.
mda
  • Russia, Moscow
« Reply #2 on: March 03, 2024, 05:15:17 »
why does no one still use electronic ignition from the MB W123? 6 cylinder engine. As authentic as possible with all the advantages of an electronic system.
« Reply #3 on: March 03, 2024, 11:50:02 »
Probably cost and availability.
