Author Topic: Re: Diagram: Thermo Time Switch, 4 Pole Relay, Cold Start Valve, Ignition  (Read 1089 times)
rayco
  • USA, PA, Luzerne
Hello all!
New member here, and I'm amid rewiring a 1965 220SE fuel inj,  manual trans vehicle.
At some point in the past, another tech tried wiring it, that is obvious.
What I'm in need of is a wiring diagram which includes the ignition system(ign. coil ect.), as well as the relays(mounted on firewall(3))
and the fuel pump(electric near fuel tank) & inj pump.
I appreciate any help you might have to offer.
Best regards
« Last Edit: March 04, 2024, 15:38:22 by rayco »
lpeterssen
  • USA, FL, Miami
Dear friend
Use the same diagram as w113-230SL published for full members on this site.
Best regards
Eng. Leonardo Peterssen
Www.wiredoktor.com
