with our official
Pagoda SL Group logo
from our official partner.
Need help on identify location of 2 wires
Topic: Need help on identify location of 2 wires (Read 2049 times)
john womble
Full Member
Junior Level
USA, NC, Sanford
March 10, 2024, 23:54:32 »
i have a 71 280sl and have rebuilt the motor. i am now in the process of restoring the wires for start up. i have a green coated wire that splits to make 2 connections. I believe they have some control on the throttle body idle sensor. The wire is located on the driver side but is not long enough to connect to the terminal located on the transmission.
ctaylor738
Full Member
Platinum
USA, VA, Falls Church
Re: Need help on identify location of 2 wires
March 12, 2024, 19:08:24 »
If you have an automatic transmission, there is an idle switch on the throttle body that has two wires running to it. Those wires come from the harness on the right side, though.
A picture would help.
CT
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #2 on:
March 12, 2024, 20:38:12 »
Is the wire in question green or green/red?
WRe
Full Member
Platinum
Germany, Hessen, Seeheim-Jugenheim
Reply #3 on:
March 13, 2024, 07:29:34 »
usually the constant speed solenoid is connected to both oil pressure switches via a green/red wire that splits into two, see
https://www.sl113.org/wiki/Automatic/Start#AutomaticTransmissionWiring
but I have seen lime green wires with red line too.
...WRe
Last Edit: March 13, 2024, 07:39:39 by WRe
Full Member
Platinum
Reply #4 on:
March 13, 2024, 11:05:22 »
That is exactly the wire I was after. Switch to switch to CSD.
