Author Topic: Soft top gap  (Read 843 times)
Savakis
  • Greece, Central Macedonia, THESSALONIKI
Soft top gap
« on: March 11, 2024, 23:19:52 »
Hello, after I managed to replace the soft top fabric I noticed that the rear ends of the cloth are not symmetrical.
The left side sits higher than expected and creates a horizontal gap whereas the right side seems to be closing well.
Is there a way to adjust the frame or play with the soft top's tension in order to overcome the problem?
Please check the attached pictures.
I would welcome your comments.
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
Re: Soft top gap
« Reply #1 on: March 12, 2024, 06:47:58 »
you need to reglue it again.
pull the lower part of fabric a little bit over the lower edge of the bow - all the way from left to right side. This will result in perfect fit
1964 230SL
Savakis
Re: Soft top gap
« Reply #2 on: March 12, 2024, 07:20:43 »
i'll give it a try, many thanks.
