Author Topic: plastigauge measurements  (Read 1049 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: March 12, 2024, 13:46:56 »
Hi all
My question is... when overhauling an engine,it is usual to check the clearances between cranshaft journals and their covers, as well as connecting rods and their covers, to make sure the oil pressure will be fine...
When using plastigauge to measure the clearance, may we understand that we have to :
- torque to nm + angle tightening as it would be for the final assembly before then... undoing everything to check and compare the width of the plastigauge ?
OR
- torque to nm only WITHOUT angle tightening ?
My question is more about the bolt resistance during this checking, as I think, those cannot be reused after this strong torque sequence...
As a consequence... buying new cranckshaft bolts appears very expensive, this is why I was wondering what is the normal way of checking platigauge...
thanks for your advices...
« Last Edit: March 13, 2024, 06:57:01 by Figoulu »
1965 230 SL
1991 Porsche 911/964 carrera 2
1990 Porsche 911/964 carrera 4 SOLD
2020 Harley Davidson Fatboy
2018 Harley Davidson Street Bob SOLD
2003 Harley Davidson Road King Classic SOLD
2017 Harley Davidson softail Slim SOLD
2008 Harley Davidson Softail Fatboy SOLD
My youtube channel #lfgdf
Figoulu
Re: plastigauge measurements
« Reply #1 on: March 14, 2024, 09:43:12 »
No clue anybody ??  ::) ::)
1965 230 SL
DaveB
« Reply #2 on: March 14, 2024, 17:53:44 »
Well I don’t know for sure but I don’t think the additional angle beyond the specified torque reduces the bearing clearance, just stretches the bolt slightly for better clamping.
Someone with more experience will help soon!
DaveB
'65 US 230sl 4-speed, DB190
« Reply #3 on: March 15, 2024, 05:02:37 »
The connecting rod bolts can be re-used unless they are stretched beyond factory specifications. Normally they are not but should be measured. The specifications for length of the stretch bolts should be in the BBB or the "Technical Data Manual". I also agree that the final angle of rotation should not make a difference in the clearance.
Figoulu
« Reply #4 on: March 15, 2024, 10:39:27 »
Ok thanks
So as I understood, simple torque spec WITHOUT angle tightening is enough for plastigauge measurement !
1965 230 SL
