Author Topic: parts advice  (Read 774 times)
NZ230
  • New Zealand, Canterbury, Christchurch
parts advice
« on: March 14, 2024, 07:02:42 »
I was wondering what the best source of parts is. Namely brake master cylinder and wheel cylinders.
I have a barnfind type vehicle. Engine runs now but brakes are gripping. Wheels can rotate but not so freely. I was planning on replacing parts as above and flexible hoses with bleed etc.
Thanks in advance
Hemal
WRe
Re: parts advice
« Reply #1 on: March 14, 2024, 08:09:40 »
whem I'am looking for spare parts I often use https://www.daparto.de/ first to get a good overview. In order to get a precise overview, I use the usual KBA numbers HSN/TSN for our vehicles here in Germany, see "Fahrzeugauswahl nach KBA-Nr." which means "vehicle selection according to KBA number".
          HSN/TSN
230SL 0009/334
250SL 0009/345
280SL 0009/380
Spezialized sources here in Germany are
- https://www.sls-hh-shop.de/main/en
- https://www.niemoeller.de/en
For rare parts:
- Bruno Wenner: http://www.classic-center-versmold.de
- Werner Karasch: http://www.karasch-mb.com
- Josef Greipel: https://www.pagodenparts.com
- A.I. Motors: https://ai-motors.de/
See also: https://www.sl113.org/wiki/Suppliers/Start
...WRe
DaveB
Re: parts advice
« Reply #2 on: March 18, 2024, 04:40:51 »
You may find that new hoses will fix the problem. Though R&R of all components is a good idea if you don’t know the history. I believe the original ATE parts are best quality, at least for wheel cylinders. I had some ATE and some aftermarket (FTE?) and remember thinking the ATE were better constructed, though I don’t remember the difference. BTW those brake parts can all be rebuilt with new genuine seals and pistons as long as they’re clean inside.
If NZ prices are like AUS it would be cheaper to import, notwithstanding the import taxes. George at Authentic Classics is a reliable source. It would be worth checking his site for what you need.
DaveB
'65 US 230sl 4-speed, DB190
NZ230
Re: parts advice
« Reply #3 on: March 18, 2024, 09:22:28 »
Thanks so much for your replies
I have sourced the parts from niemoller
Actually the car has been sitting for years so may replace the master and wheel cylinders
Hopefully I can get the car moving again. It is an auto so need some braking ability!!
