Author Topic: Copper Washers for ATM Cooler Hollow Bolt  (Read 2401 times)
LA280SL
  • USA, CA, PACIFIC PALISADES
« on: March 25, 2024, 20:26:52 »
I recently replaced the ATM fluid pan gasket and removed the hollow bolt and two copper washers that connect the hard line from the transmission cooler.
To reinstall this hollow bolt (located between the converter and fluid pan), should I replace the copper washers or use existing washers?  If not, would it be wise to first apply a sealant to the surfaces of existing copper washers?
I appreciate the feedback.
LA280SL
Re: Copper Washers for ATM Cooler Hollow Bolt
« Reply #1 on: March 25, 2024, 21:48:25 »
Here is a photo of the bolt and washers.
« Reply #2 on: March 25, 2024, 22:46:58 »
Replace.
LA280SL
« Reply #3 on: March 26, 2024, 03:36:35 »
Thanks Pawel.  Will do.
« Reply #4 on: March 26, 2024, 04:13:03 »
Use aluminum seals which are softer and seal better.
« Reply #5 on: March 26, 2024, 06:30:44 »
They are available from Mercedes for peanuts, but then sometimes you get copper, sometimes aluminium.
In any hardware store you should be able to get proper diameter aluminium ones.
