Author Topic: 230SL Cooling upgrade Part Numbers  (Read 1091 times)
YEOH250SL
  • Malaysia, Sarawak, Kuching
« on: March 26, 2024, 05:52:57 »
Does anybody know the individual part numbers for all the items in this package offered by Bud's?
https://www.budsbenz.com/catalog/230-250-280-sl/z-air-conditioning/Z830-003E
Thanks.
WRe
Re: 230SL Cooling upgrade Part Numbers
« Reply #1 on: March 26, 2024, 07:29:50 »
here are details, some are already discussed very often, e.g. https://www.sl113.org/forums/index.php?topic=25187.0 .
- Fan shroud: 1135050555 replaced by 1135050655
Bud's remake doesn't look very good. In my opinion even an aligned W108/W109 plastic shroud (1085050255, 1095050855) looks better.
- 9-blade fan:
For cars with air contdition (US) originally an 8-blade fan was used (A1082050206, A1082050506). Thes 9-blade fans are still availabe for small money (A1102000323).
The more blades the louder.
- Visco clutch: A0002000422
There are many cheap reproductions available.
- Water pump: A1102001720
- A/C pulley: A1292050410
Only necessary with A/C.
In my opinion, it's grossly overpriced.
...WRe
YEOH250SL
« Reply #2 on: March 26, 2024, 08:39:04 »
WRe,
Your knowledge is very much appreciated. I agree that Bud's charging an arm and a leg for the set. Much cheaper to buy individual parts from your favorite parts shop. Once again, thanks for the help.
YEOH250SL
« Reply #3 on: March 26, 2024, 08:48:31 »
There 2 versions of the water pump. The long one and the short one. Are they interchangeable?
dirkbalter
  • USA, CA, Corona
« Reply #4 on: March 26, 2024, 16:48:30 »
Yes, they are. The short one requires a spacer. IMO the long one is better unless you have the spacer and corresponding hardware.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
YEOH250SL
« Reply #5 on: March 27, 2024, 00:25:08 »
Got it, Dirk. Thanks
