Hi, so ended up pulling out the Arm but cannot figure out how to get the VDO Black switch off? Seems like it is 2 parts. I don't remember if it worked ( I know the blinkers did). The wipers never worked so never tried those functions. Figured I would check it out before I asssumed it work... It seems to move around but I don't want to pull it and snap something because it is plastic... I thought I read somewhere that you had to drill out a little hole but can't find that post now and wanted to check if that is really the only option?
A
