Leonardo, thank you for your kind attention!
I did a brief check when I got charging lamp permanently on, increasing intensity slightly as I revved up engine, going dark when I let it go down to idle, then getting bright at idle again.
Steady voltage 12.46V on battery regardless of revs. Headlights not brightening up on reviving up.
V-belt tight.
Swapped another regulator - same status. I concluded that alternator is shot, but wanted to check surroundings.
Saw on wiring diagram D- is fixed to ground. I checked the pin on the regulator plug vs. Car body - no ground. I took a piece of wire, connected the plug to ground - same effect, did not help.
That is when I had to leave it.
I do have additional ground strap for alternator.
The nearest ground point is the one for washer motor. But I think it is only for the washer motor.
I will do the checks as you described when I am back on Friday. Thanks again!
