Author Topic: M127 Illegible Engine Number  (Read 1089 times)
YEOH250SL
  • Malaysia, Sarawak, Kuching
« on: April 04, 2024, 01:51:37 »
Hello, the engine number on my 230SL have been corroded and the tag is missing. Are there any other location on the engine where I can find the engine number? I have attached a pic of it. Appreciate it if someone have a hint.
Re: M127 Illegible Engine Number
« Reply #1 on: April 04, 2024, 04:38:02 »
Very unusual. I would venture a guess that this is not the original engine, but a replacement that whoeever fitted it did not do the best job stamping in the (probably same as the original) engine number. That part of the engine block does not corrode to any appreciable extent.
I know nothing about data cards, but would imagine that would show the original engine number.
« Reply #2 on: April 04, 2024, 04:59:26 »
That's the only place you'll find it on the car.   :(  Some numbers are readable, but not enough to be useful.  Like Cees said, that area isn't really corroded.  It just looks like a bad stamping.  That's going to make engine specific parts ordering difficult.  You don't know what it is.
YEOH250SL
« Reply #3 on: April 04, 2024, 05:01:39 »
Fellas, I suspected the same thing. Thanks for the confirmation.
« Reply #4 on: April 04, 2024, 05:12:36 »
It seems the stamping is usually across the top of that flat area.
https://www.sl113.org/wiki/DataCard/EngineNumber
Yours is at the bottom.  Maybe it is a replacement block.
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #5 on: April 04, 2024, 10:04:21 »
Try putting some oil on the area and use a wire brush.  It may clean it out a little.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
DaveB
« Reply #6 on: April 04, 2024, 12:01:24 »
This suggestion should help. And shining a light from the side might pick out the numbers better.
DaveB
'65 US 230sl 4-speed, DB190
YEOH250SL
« Reply #7 on: April 04, 2024, 12:47:37 »
Ok, I Will give it a go. Thanks
