Author Topic: 5 speed zf gearbox fluid  (Read 3752 times)
mauro12
  • Italy, Sicily, Messina
« on: April 06, 2024, 16:30:54 »
Hi guys , yesterday I was in my local Mercedes Benz dealer and I saw for sale the genuine Mercedes atf 236.14. I was wondering if it’s a good idea to put in my 5speed zf gearbox or is a too modern version for our cars .
Last time I replaced the oil was 4 years ago with regular atf ( maybe from castrol ). The original service manual says to replace the manual gearbox fluid every 20.000km but doesn’t explain how often if you don’t cover that distance ( I do barely 1000km per year ). What do you think it’s a good idea ?
Same question for the differential oil , in this case is recommended 75w90.
Thank you
Mauro Pisani
250sl 1967 5speed zf manual
mauro12
Re: 5 speed zf gearbox fluid
« Reply #1 on: April 07, 2024, 10:51:21 »
Any ideas ?
Mauro Pisani
Jowe
« Reply #2 on: April 07, 2024, 18:54:34 »
In the Enthusiast Service Manual, page 5, you will find all the fluid specs. See https://www.sl113.org/wiki/Restricted/ServiceManual
Johan
« Reply #3 on: April 07, 2024, 22:18:29 »
I use a synthetic ATF in my car. For such a rare and valuable item why not use the best you can get.
1988 560SEC
mauro12
« Reply #4 on: April 07, 2024, 22:38:27 »
Genuine Mercedes atf ( probably made by Petronas ) would be ok or maybe too modern ?
Mauro Pisani
MP
  • United Kingdom, England, Lydeway Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
« Reply #5 on: April 13, 2024, 10:59:18 »
ZF recommend a 75w80 ( Ecofluid M ) for the S5-20 gearbox, look on their site and gearbox list and fluids.
An alternative is Pakelo Golden gear LD Plus, similar spec .
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
mauro12
« Reply #6 on: April 14, 2024, 17:41:15 »
That’s strange because Mercedes has always recommended atf
Mauro Pisani
MP
« Reply #7 on: April 14, 2024, 19:41:24 »
ZF make the box, look at their site.
2000 Ducati 748s
1970 Ducati Monza
« Reply #8 on: April 14, 2024, 20:02:54 »
I'm sure MB would have been using ATF back when the car was new. They would be the ones covering warranty.
1988 560SEC
MP
« Reply #9 on: April 14, 2024, 21:46:34 »
I'm not saying don't use it, I was but things move on.
2000 Ducati 748s
1970 Ducati Monza
DaveB
« Reply #10 on: April 15, 2024, 02:51:47 »
ATF would be worth trying..at least you know it won’t do any harm.
I see the pdf that recommends Ecofluid M also recommends a wide range of other transmission and engine oils for use in the ZF S5-20.
DaveB
'65 US 230sl 4-speed, DB190
DaveB
« Reply #11 on: April 15, 2024, 03:01:53 »
As to whether that specific ATF 236.14 is good for the job Mauro, I don’t know but you can check it’s specifications against those in the pdf and Jowe’s link.
Only 1.1 litre required so yes ‘use the best you can get’.
DaveB
MP
« Reply #12 on: April 15, 2024, 08:12:23 »
I was told by a gearbox engineer the ATF gives a good change but does not protect the gears like the 75w80.
2000 Ducati 748s
1970 Ducati Monza
mauro12
« Reply #13 on: November 10, 2024, 15:27:40 »
HI ; in the mercedes owners manual is written to use atf type a which no longer exist . Some days ago i was in my local mercedes dealer and i was looking at genuine fluids. My question is still the same : Are modern atf (236.15) compatible with the 5speed zf or not ? i've always used regular atf from castrol or motul.
Mauro Pisani
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #14 on: November 10, 2024, 16:21:14 »
I have Euro spec 4 speed manual, I use
MERCON ATC. The new product is Denton III.
Robert Hyatt
Williamsburg, VA.
mauro12
« Reply #15 on: November 10, 2024, 16:22:49 »
I was thinking if the latest atf from
Mb could improve the shifting , since it is more fluid .
Mauro Pisani
MP
« Reply #16 on: November 10, 2024, 16:25:29 »
If ZF recommend Ecofluid M  75w80 why would you be looking for an ATF
2000 Ducati 748s
1970 Ducati Monza
mauro12
« Reply #17 on: November 10, 2024, 18:30:56 »
That’s an interesting topic because is no sense . Zf reccomend one thing and Mercedes another thing . I’ve read too that zf suggest 75/80 , I’m just wondering why .
I guess the shifting with 75/80 is much heavier than atf .
Mauro Pisani
MP
« Reply #18 on: November 10, 2024, 23:11:11 »
Do Mercedes really still recommend ATF ? Wouldn't they take the advice from ZF who make the gearbox. ATF was recommended originally but time and things move on.
« Last Edit: November 10, 2024, 23:16:18 by mazmonza »
2000 Ducati 748s
1970 Ducati Monza
mauro12
« Reply #19 on: November 11, 2024, 10:45:09 »
I believe so . Maybe more expert in the forum can clarify this aspect .
Mauro Pisani
« Reply #20 on: November 12, 2024, 18:05:45 »
Back when I worked in the dealership (40 years ago....) we used ATF 200 in all manual gearboxes. It was a gold colour rather than the red of the ATF 220 we put in autos.
mauro12
« Reply #21 on: November 13, 2024, 18:34:22 »
You were working in a Mercedes dealership back 40years ago ?
Mauro Pisani
AndrewB
  • United Kingdom, Channel Islands, Forest
« Reply #22 on: November 13, 2024, 21:07:30 »
This is why stick knows so much about our Mercedes Benz cars ! He was trained by Mercedes Benz and has worked on these cars his whole life. His workshop is a wonderful place to visit
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
« Reply #23 on: November 14, 2024, 10:16:28 »
Sad but true!  ;D
