Author Topic: Notchy gear change  (Read 945 times)
mazmonza
  • United Kingdom, England, Lydeway Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
Notchy gear change
« on: April 10, 2024, 18:04:36 »
Just had a new crankshaft & flywheel fitted to my 250sl ZF 5 speed, now it is awkward changing gear especially notchy in first and second.
Any ideas why?
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
ejboyd5
  • Southold, NY
Re: Notchy gear change
« Reply #1 on: April 11, 2024, 11:07:31 »
Explain "notchy."
« Reply #2 on: April 11, 2024, 16:13:00 »
Most manual gearboxes uses a 80 or 90 grade oil. These use ATF. If the wrong oil is used you'll get a notchy shift.
mazmonza
« Reply #3 on: April 12, 2024, 17:42:30 »
ZF recommend a 75 w 80  ( Ecofluid M )  for the S5-20 which I was using prior to the new flywheel.
2000 Ducati 748s
1970 Ducati Monza
lreppond
  • USA, CA, San Leandro
« Reply #4 on: April 12, 2024, 21:10:45 »
For those of us not familiar with the British term “notchy”, I found this:
A manual gear shifter is said to be “notchy” if it is difficult to select a gear from neutral.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
mazmonza
« Reply #5 on: April 12, 2024, 22:10:41 »
Well done 😄
2000 Ducati 748s
1970 Ducati Monza
DaveB
« Reply #6 on: April 15, 2024, 03:24:15 »
Maybe it will improve after some bedding in time. Has the weather been colder than usual? Do you think the clutch is disengaging completely as it should? You could also look below for possible binding in the selector mechanism or rods.
Or try ATF, though if it was previously fine with the Ecofluid that may not change anything.
DaveB
'65 US 230sl 4-speed, DB190
mazmonza
« Reply #7 on: April 15, 2024, 08:05:37 »
Thanks Dave, I will look at the mechanisms, I don't think it's the Ecofluid which I have been using for over 2 years. Have attached list from ZF if anybody is interested.
Maurice
2000 Ducati 748s
1970 Ducati Monza
