Author Topic: Installing the heater radiator  (Read 2080 times)
CJHenderson
  • USA, AR, Benton
« on: April 27, 2024, 16:50:18 »
I'm in the process of installing the heater radiator in place of a total piece of junk AC, but I noticed that SLS showed what looks like a dog bone connecting from the radiator valve to the control lever. Where can I get one since the heater didn't have one when I had removed it from the car due to it being deactivated.
1950 MG-TD
Re: Installing the heater radiator
« Reply #1 on: April 27, 2024, 20:32:29 »
Buds Benz here in the States indicates that a person can contact them for non-listed parts. They might have one from a car in their boneyard.
https://www.budsbenz.com/catalog/230-250-280-sl/x-heater-ventilation
Or perhaps someone here with a parts car might be of assistance.
CJHenderson
  • USA, AR, Benton
« Reply #2 on: April 29, 2024, 23:51:06 »
Thanks for the advice. I'm ordering both L&R ball ends and then get a 5mm rod and cut both L&R threads. trying to find a dog bone for the heater valve seams to be a bridge to far.
1950 MG-TD
dirkbalter
  • USA, CA, Corona
« Reply #3 on: April 30, 2024, 00:39:29 »
In the picture is my rod when I removed it.  The dimension is center to center ball-end. That should get you close. I don't think you need left / right hand threads. AFAIR you can't adjust the rod once installed.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
CJHenderson
  • USA, AR, Benton
« Reply #4 on: May 01, 2024, 14:40:10 »
Awesome thank you, you just saved me a lot of time and frustration.
1950 MG-TD
