Author Topic: Trunk luggage strap dimensions  (Read 7647 times)
Ronmurr
  • USA, CA, San Juan Capistrano
« on: April 29, 2024, 18:38:28 »
Just wondering if anyone knows the width and approximate length of the luggage straps for the trunk. The one that hooks into the two brackets.  looking to have one custom made.  thanks
Re: Trunk luggage strap dimensions
« Reply #1 on: April 29, 2024, 18:59:45 »
Someone may have the overall dimensions, but in the meantime you can use the search function, fourth item over from "Home" on the forum page. I used "luggage strap" (without the quote marks) and got a single page of hits. No exact dimensions, but there are some close up photos that show how the strap fits into the brackets in the trunk that should give you some idea.
dirkbalter
  • USA, CA, Corona
« Reply #2 on: April 29, 2024, 19:11:04 »
According to the info from the German site, these are 25mm wide, 2.5mm thick. One is aprrox. 29.5cm and the other one is 78cm long.
Do you have the pins / hardware?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Ronmurr
« Reply #3 on: April 29, 2024, 20:14:09 »
Thanks for the info. No forgot about the pins Attached the strap to the trunk any idea of their approximate dimensions ?
« Reply #4 on: April 29, 2024, 21:02:46 »
Could that be determined by measuring the brackets/anchors?
Ronmurr
« Reply #5 on: April 30, 2024, 01:22:57 »
Yeah, didn’t have any luck on dimensions just some photos.
dirkbalter
  • USA, CA, Corona
« Reply #6 on: April 30, 2024, 02:05:58 »
Ron,
See attached. Again, borrowed from the German forum.
Let me know if you find someone who can make the straps. (PM me) I am interested too. I can make to pins.
« Last Edit: April 30, 2024, 02:14:03 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #7 on: April 30, 2024, 03:35:52 »
Hey guys, I'd be interested in a luggage strap.  I hope this works out.
« Reply #8 on: April 30, 2024, 10:52:48 »
This is easy enough to reproduce and there are plenty of leather workers who can do this.
If we can get some more accurate measurements, leather color, etc. we can put out RFQs.
Davek1
  • United Kingdom, England, Wells
« Reply #9 on: April 30, 2024, 13:25:56 »
I too would be interested in one.
lagolag
  • Sweden, Västra Götaland, Askim
« Reply #10 on: April 30, 2024, 22:11:07 »
I bought a replacement shoulder strap for laptop bag in natural leather from Gusti leather, it is perfect as luggage strap for our cars.
230SL 1967 since July 2021
SL55 AMG 2003 since July 2008
Suzuki Cappuccino 1995 since May 2006, Sold
Hamid Turbo
  • USA, CA, Los Angeles, Los Angeles
« Reply #11 on: January 16, 2025, 20:30:23 »
thanks for your source recommendation, i have ordered one, just curious where to get the pins. cheers
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #12 on: January 17, 2025, 22:32:35 »
I had mine made, I will try to find the leather smith who did these straps. This was about 15 years ago I had them made. They are made from original old MB parts stock that the leather smith had in his possession to use as a pattern for these belts. Can’t remember cost, but back then maybe $100. Male end is 78cm long, female end (with buckle) is 30cm, thickness (two layers) 2.5-3mm, and width is 25mm. They are stitched along both sides, with two belt loops. Mine is in black, but he can stain in different colors. The pins are made of stainless steel bar. I will look tomorrow for his contact information.
Robert Hyatt
Williamsburg, VA.
AndrewB
  • United Kingdom, Channel Islands, Forest
« Reply #13 on: January 18, 2025, 18:47:58 »
I would like 2 of these straps if we end up ordering !
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
« Reply #14 on: January 20, 2025, 01:05:30 »
I would also be interested in one set.
Maybe something that could be done as a group buy if there is a supplier.
Tomnistuff
  • Canada, Qc, Levis
« Reply #15 on: January 30, 2025, 23:53:28 »
I made the pins from a 1/4" diameter socket wrench extension  ( It is already chromed and the ends just need to be filed and polished if you are anal like me.)  Just cut the pin lengths to equal the width if the brackets, then chamfer the cut ends for safety.  You need four.
Tom Kizer
lagolag
« Reply #16 on: January 31, 2025, 16:08:53 »
I used a threaded sleeve and screws with a larger collar, see pictures.
yves
  • France, Poitou-Charentes
« Reply #17 on: February 05, 2025, 10:56:32 »
Here is what i have done last WE.....!
I have used for the first time ( for a real part)  my recent "New old Lathe" just refurbished and painted . I bought the leather strap and buckle + rivets at a leather shop .
Job done with pleasure  ;)
yves
« Reply #18 on: February 05, 2025, 10:57:04 »
At the end :
AndrewB
« Reply #19 on: February 05, 2025, 12:50:16 »
Yves, are you open for orders  :)
1987 500SL
BobH
« Reply #20 on: February 05, 2025, 12:57:07 »
Nice work Yves, you could set up a production line, lots of practice on the lathe
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
zoegrlh
« Reply #21 on: February 05, 2025, 13:35:46 »
Really great job. Yes you should take orders.
Robert Hyatt
Williamsburg, VA.
yves
« Reply #22 on: February 06, 2025, 09:57:51 »
Ok Guys… i l’ think about that , i have a mate who can help me for a série….
I’ll tell you what  could be the price!
Norm
  • USA, TX, Wimberley
« Reply #23 on: February 25, 2025, 20:03:06 »
I searched the site and found Ollie Dare.  He is still making these to OEM specifications.  Got mine today.
Ollie said it would be OK to post his contact information.
His website was hacked so you can't go there but email and phone are good.
I was just looking to set up a display for local car shows, Cars & Coffee etc.
I found two pieces of Hartmann luggage in excellent condition at a local thrift shop for $30 US each.
Norm
Norm
1966 230SL 162H Blue-Grey
1994 Acura NSX Formula Red
2024 Acura RDX A-Spec, White Pearl
2016 Mercedes S63 AMG Coupe Obsidian Black
2011 Harley Davidson Super Glide Light / Dark Root Beer
yves
« Reply #24 on: February 26, 2025, 09:21:29 »
I can now take the orders if someone is interested..... Price is 50 eur for the complete strap . + Shipping .
Work will be done by a mate who has a much better skill on the lathe than me ....! and who has also the leather skills needed.
