Author Topic: Original padding/insulation under floor mats?  (Read 2242 times)
sl113newguy
  • USA, CA, Palo Alto
  • ...just getting started
« on: May 02, 2024, 16:21:58 »
Somewhat recently purchased a 68 280SL, and still learning about the car.
Recently I found that moths (!) were starting to appear, and lo and behold found them enjoy the padding/insulation that is under the floor mats.   >:(
I hadn't looked at this before, and am curious:
1. If under-floor-mat padding was original to these cars, or an owner would have added it later?
2. Regardless, I have removed the padding - it is partially disintegrated - but figure I should hang on to them after killing off the offending months (don't ask how my wife feels about the padding being in the freezer this week) as I want to keep everything that was original to the car with the car. Anyway, I was wondering if it was original, if there is "new" padding that owners use as replacement?
Thanks everyone!
1968 280SL Automatic (USA) 350 Medium Blue
Re: Original padding/insulation under floor mats?
« Reply #1 on: May 02, 2024, 17:42:37 »
Just curious, is this under carpet or rubber floor mats?
sl113newguy
« Reply #2 on: May 02, 2024, 18:16:14 »
These were under the floor mats
« Reply #3 on: May 02, 2024, 19:40:17 »
I'm asking the material of the floor mat - rubber or carpet?  I didn't know if early 280's still had rubber mats.
sl113newguy
« Reply #4 on: May 02, 2024, 20:23:39 »
Ahh, gotcha. I didn’t realize there were multiple kinds of floor mats.  ::)
Mine look like carpet with some kind of coating on the back.
« Reply #5 on: May 02, 2024, 20:37:04 »
They probably changed mid-250SL when so many things changed.
Search this forum for "Cocomat", if you're unfamiliar with that company.
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #6 on: May 02, 2024, 20:37:20 »
Those are original pads under the mats.  Mine are still in the car and like new...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
john.mancini
  • USA, FL, Nokomis
« Reply #7 on: May 10, 2024, 00:37:19 »
I agree, those are original. I've had them on many Pagodas over the years.
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
Benz280
  • USA, NJ, Jersey City
« Reply #8 on: May 10, 2024, 20:59:07 »
For reference, under the drivers side their is a secondary mat below the accelerator.  Looks to be made by a company called Chadwick .
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
sl113newguy
« Reply #9 on: May 10, 2024, 22:49:02 »
Thanks everyone. The original floor mats have a bit of a fade, but at some point an earlier owned added a couple of (Palm Fibre) Cocomats, which don't look too bad  :D
A question on Dynamat - when those are added and stuck to the floor of the vehicle, is it easily removable later (say if I want to remove it, the next owner in 50 years wants to remove it, etc.)? Or to later get it off does it involved removing paint, etc.?
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #10 on: May 20, 2024, 23:06:03 »
I would think you could use a heat gun to remove Dynamat.
Robert Hyatt
Williamsburg, VA.
