Author Topic: Mercedes W109-4.5 Wiring Harness Challenge  (Read 2426 times)
lpeterssen
  • USA, FL, Miami
« on: May 06, 2024, 14:16:45 »
Dear friends
I am in the middle of a challenging harness set project for a customer in Saudi Arabia.
This is a harness from a very rare car W109-4.5 300SEL which total production number is in the range of the 2,500 units.
Certainly it is a very demanding project/customer with a harness considered trash for anybody. It was chopped at the firewall  entry point.
The harness rest shown on picture had a repair attempt before me.
The condition of it obligated me to built all circuits from scratch with no splices anywhere.   That process has been developed in detail matching in 90% de original cable color scheme.
Wish me luck
Best regards
Leonardo Peterssen
Www.wiredoktor.com
https://www.icloud.com/sharedalbum/#B0Q5Q2ydoG6KCEG
« Last Edit: May 06, 2024, 14:40:48 by lpeterssen »
RAY
  • United Kingdom, England, Bromley
Re: Mercedes W109-4.5 Wiring Harness Challenge
« Reply #1 on: May 06, 2024, 17:33:06 »
Wow, unbelievable what you do, I would not know where to start.
I don't think you need to much luck, from your past posts you appear to know exactly what your doing but what I think you do need is a lot of time and patience.
But good luck anyway.
lpeterssen
  • USA, FL, Miami
« Reply #2 on: May 06, 2024, 17:35:16 »
Thanks a lot.  I think the key conditions are to be patient and organized.
Best regards
L.Peterssen
Www.wiredoktor.com
Baybear
  • USA, VA, Midlothian
« Reply #3 on: May 07, 2024, 23:36:16 »
I have a 1972 300sel 4.5. If I can help in any way with pictures etc. Let me know. Only 2553  of these made from 1971-1972 at a cost of about $14,100 US.
Will
« Last Edit: May 07, 2024, 23:48:47 by Baybear »
Will Milby
1970 300SEL 6.3, 1971 280SL, 1972 300SEL 4.5, 1972 Super Beetle, 1998 SL500, 2010 350 GLK, 2012 SLS AMG
lpeterssen
  • USA, FL, Miami
« Reply #4 on: May 07, 2024, 23:43:58 »
Dear Will
Many thanks for your kind offer.  I am using as a guide another wiring harness set I have from a similar car:
  • A harness set from w108-4.5
  • A harness set from a w109-300 with  M189 engine
But nevertheless I got one cable branch which is chopped inside the cabin that I have not identified according to wiring diagrams what for it is.
There are two cables, one light green going together with a blue wire.  Those are close to the connector for the AC EVAPORATOR UNIT below the dashboard.  I have no idea what for are they?
It is not related to the FASTEN SEAT belts warning system.
It may be related to the AC system, maybe it feeds a bulb on the ac control panel ,to let the user know when the compressor clutch is engaged…..
If you have any ideas… will be received with joy.
Best regards
Leonardo Peterssen
Www.wiredoktor.com
Baybear
« Reply #5 on: May 07, 2024, 23:59:39 »
The car is currently about an hour and a half away in our second home in Deltaville, VA. I should be able to go down there on Thursday and see what I can do. Perhaps take some pictures from underneath the dash to help you. I assume the wiring harness on a 1970 6.3 is different. I have one of those in my garage here in Midlothian, VA.
Will
Will Milby
lpeterssen
  • USA, FL, Miami
« Reply #6 on: May 08, 2024, 00:07:07 »
Dear Will
Yes the harness from a w109-6.3 is totally different.  I have one full harness set of those here and I also own a w109-6.3 1969.
I will send you a PM to stay in touch.
No problem if you can go over the 109-4.5 on Thursday.  Still have lot of work on this harness and that can wait until many other things are sorted out.
Best regards
Leonardo Peterssen
Www.wiredoktor.com
lpeterssen
  • USA, FL, Miami
Almost finished as May 16.24
« Reply #7 on: May 17, 2024, 12:27:59 »
Dear friends
I am getting there. What appeared to be impossible is now close to its final completion.
The w109-4.5 chopped harness has become the pristine beauty shown on pictures attached.
The customer is more than happy with the outcome.
1. All relays changed to cubed style pin arrangement
2. Fully functional emission control system
3. Intermittent wipers rare option added with original Mercedes Impulsegeber relay
4. Matching 3 speed steering wheel switch added
Here shared album link with high res photos and comments
Best regards
Eng.Leonardo Peterssen
Www.wiredoktor.com
« Last Edit: May 17, 2024, 15:58:47 by lpeterssen »
RAY
« Reply #8 on: May 26, 2024, 17:28:30 »
Amazing work.
Congratulations on a demanding job.
lpeterssen
  • USA, FL, Miami
« Reply #9 on: May 26, 2024, 19:05:27 »
Dear RAY
Many thanks for your comments on my work.  It really feels good when people appreciate what I do.
Best regards
Www.wiredoktor.com
